lateski
Hello!
I'm in the middle of a cylinder head repair of a 2019 T6 with a CXHA engine. It has a teethless timing belt(~1,5 years/75k km driven) resulting to valve and camshaft module damage.
I already had the head refurbished with new valves and before I fitted the new camshaft module it seemed to be far too different from the old one, so it made me unsure about quality of the new part.
The old module is 04L 109 071 E and it was supersede with 04L 103 044 AG, so I ordered the later module.
To the matter itself. Here is a picture of the modules. Old on the left and new on the right. Both are set around the TDC and all of the exhaust camlobes are misaligned with eachother, but the intake camlobes are identical in each module with the G40 trigger wheel, but the shaft itself is 180° off with eachother.
In the old module cylinders 2 and 3 had clearly spun cam lobes and those had also two broken rocker arms.
Do I have a case of spun exhaust cam lobes and a spun gears between shafts? Could the exhaust cam lobes spin each one equally as much? What do you think?
By looking at the new module the camlobe positions seems to be in place thinking about the engine work cycle, but I'm really uncertain about this situation. It's my first cylinder head repair to this generation engine and I have earlier worked around cast camshafts.
I'd like to have pictures of a known good camshaft module, if you have some, to make sure that the new module is good to fit the engine.
