No, PDC module 10 doesn’t require security access - or at least mine doesn’t.Yes, this is the one that requires security access? If so then yes it has been activated I have attempted numerous searches for further info to no avail
Good to hear you got it sorted!Update! Breakthrough - I now have park pilot functioning on my head unit! I have attached a photo of the adaption which was needed in module 5f to enable this.
My only question now is, does the park pilot usually switch off once taken back out of reverse gear or is there usually a delay? This may be because I’m not driving away at speed (testing on the drive) however it seems to stay on just a little bit longer than I would like? If this is so can this be changed via VCDS?
I don’t see why the brackets would need to be changed. But sensors are pretty tight fit to the brackets, perhaps it’s easy to break them while removing sensors?Hi all.
I need to replace the rear sensors on my bus, after the previous owner had painted over them in a move to carry out a cheap respray job. This has changed the accuracy of the sensor itself so I want them replaced. Did i read somewhere that it is best to replace sensor holder bracket at the same time, or should it be a case of being able to pull out/unplug the sensor and plug in a new one..... ?
Thanks, Pauly. Yes, I am considering exactly one of these retrofit kits that's supposed to work exactly as the factory installed system. I would gladly have a shop do the installation, but out of 10 shops I spoke with only 2 were willing to do the coding - others said they don't do this type of work. I'd say I'm pretty handy, but to decide whether I'm ready to undertake this project I would like to have a better understanding of the scale. Taking off the bumper is within my comfort zoneYou can buy retrofit kits to do it in the factory style, it’s reasonably involved as the wiring runs the length of the van, control module and speaker go in the lower dash area and the bumper needs to come off to cut the holes in it (requires a particular tool to do it neatly)
If you are happy/confident to take things apart etc then it is achievable but it’s certainly not an hour or two job
@mmi is from your part of the world and may be able to advise regards programming etc ?
In the downloads:Does anyone have any wiring diagrams for the rear park assist for t6?
OEM location in the downloads - page 42Particularly curious where the PDC module should be placed
How about a camera retrofit?The van does not have any factory installed park assist, so backing up in a crowded parking lot is a challenge.
