retrofited CC works but error codes
ArtD
Hi there,
Would welcome some direction on the VCDS errors regarding CC retrofited - I have tested CC and it works as it should (on/off/accelarete,reduce speed/increase speed/ clutch etc) but I get vcds error codes (note this is UDS one so no measure blocks but advance mesures which I tested too). I have included my scan log below. I'm aware of glow plug error (need to change it), and radio as aftermarket one (removed from the list now)
Note: I have changed BCM, retrofited CC and MFSW (CC works and MFSW works). There are other errors not sure why e.g. contorl module incorrectly coded as well as terminal 30 errors.
Any support welcomed - initially with CC. thank you
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
56-Radio -- Status: Not registered 0011
Address 01: Engine (J623-CAAB) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 022 CD HW: 03L 907 309 K
Component: R4 2,0L EDC H37 9970
Revision: 26H37--- Serial number: 00000000000000 CVN: CCAEB9E1
Coding: 01114010232400080000
Shop #: WSC 22306 002 104857
ASAM Dataset: EV_ECM20TDI01103L906022CD 002014
ROD: EV_ECM20TDI01103L906019AM_002.rod
VCID: 69D908A38879EBDB7C-803C
VINID: 9E606AAAA1D8A926000C524108AFE2B823
3 Faults Found:
4481 - Cruise Control Switch (E45)
P0568 00 [047] - Implausible Signal
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 172893 km
Date: 2024.07.21
Time: 01:00:32
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 80 °C
Intake air temperature: 35 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 12.380 V
Unlearning counter according OBD: 40
Cruise Control System (CCS): switch position-Bits 0-7: 192
Cruise Control System (CCS): status-Bits 0-7: 8
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise Control System: specified speed: 0.00 km/h
Engine control module reset status-Bits 0-7: 0
Engine control module reset status-Bits 0-7: 59
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4482 - Function Restriction due to Implausible Message(s)
U1112 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Mileage: 172893 km
Date: 2024.07.21
Time: 01:00:32
4986 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 00 [047] - Electrical Fault
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 172893 km
Date: 2024.07.21
Time: 01:23:46
Engine RPM: 1048.50 /min
Normed load value: 25.1 %
Coolant temperature: 16 °C
Intake air temperature: 16 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 11.380 V
Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
Electric auxiliary heater: relay activation-Bits 0-7: 0
Pre-glow time: 800 ms
Glow status-Bits 0-7: 0
Glow cycles above temperature threshold-Bits 0-7: 0
Glow cycles below temperature threshold-Bits 0-7: 21
Glow cycles below temperature threshold-Bits 0-7: 224
Outside temperature: 13.0 °C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 G HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0105
Revision: 00H43001
Coding: 508724AD89A70A9A24AB9172A96010
Shop #: WSC 02736 790 49152
VCID: 366393DF8147742321-8062
No fault code found.
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 F HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0230
Revision: BO047001 Serial number: 0396 301100247
Coding: A0A0393A0E212011002800003C2B8C500080430F60060000300000000000
Shop #: WSC 02734 790 12345
VCID: 377D9EDB864D8D2B3A-8062
Subsystem 1 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3311
Serial number: --------------------
Coding: 010000
Subsystem 2 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3311
Coding: 000000
Subsystem 3 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Serial number: 30000000000000368706
Coding: E30000
4 Faults Found:
03430 - Terminal 30 for Turn Signals and Brake Lights
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 129
Time Indication: 0
00959 - Indicator Lamp for Central Locking; Safe (K133)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 91
Time Indication: 0
03396 - Supply voltage terminal 30 for central locking
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 129
Time Indication: 0
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Mileage: 172893 km
Time Indication: 0
Date: 2018.12.12
Time: 00:00:01
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H06 0013
Revision: -------- Serial number: 003HL0013B4H Dataset Number: 7E0003v____ 0471
Coding: 000000000000000000000000000000003039
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 356194D394417F3B28-8060
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 960 C HW: 7E0 920 960 C
Component: KOMBI H04 0204
Coding: 460A00
Shop #: WSC 02736 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 295948A348F92BDBBC-807C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 0230
Coding: 042300
VCID: 70EF65C7A3A31A133B-8024
2 Faults Found:
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2018.12.12
Time: 23:50:54
01336 - Company Data Bus for Comfort System
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 129
Mileage: 172893 km
Time Indication: 0
Date: 2018.12.12
Time: 00:53:47
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0204
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADB77AF8D7FE0C375-803E
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:24)--------------------------
Not much info here given the amount of stuff you have done
Please post a full unedited autoscan
What van is it ?
What faults were present before you started ?
What BCM did you remove and what did you replace it with ?
Where the parts new or second hand ?
etc etc
Can you post a full scan from before you started ?
What van is it ?
etc etc
Ok so I went for a ride, CC works - rescanned all, cleared errors, when for a ride again CC works, mfsw works and the only errors I get are:
Code:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2018.12.12
Time: 23:50:54
And another one about not reaching the radio.
I have removed radio from the list of 19 Can Gateway - but it still sees it. I wonder whether error is to do with mfsw where the code recognise there is a radio as it controls it (volume, channels etc.) but through connect 2 only?
Any idea?
vw t.51
fault before (glow plug only - it didn't appear on pre install but I had it when enging on)
removed 86D replaced with 86M
BCM second hand (from vw t5.1), stalk vw new (dedicated with cruise control but without trip), steering wheel second hand (from passat):
Code:
pre installation scan:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 09 15 17 19 25
VIN: WV1ZZZ7HZBH035912   Mileage: 172310km-107068miles
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
   Coding: 01114010230400080000
   Shop #: WSC 22306 002 1048576
Readiness: 0 0 0 0 1
   Revision: 00H43001
   Part No SW: 7H0 937 086 D    HW: 7H0 937 086
   Component: BCM T5GP M++4 H47 0221
   Revision: BM047001    Serial number: 0346 239100757
   Coding: A0A0393A0E212011002000003C2B8C500000430F60060000300000000000
   VCID: 3467A9D7973B66331F-8060
   Coding: 010000
   Coding: 000000
   Coding: 460200
   Part No SW: 6N0 909 901     HW: 7H0 937 086
   Component: GW-K-CAN TP20 0221
   Coding: 042300
   Serial number:
   Coding: 000000
End-------------------------(Elapsed Time: 01:54)--------------------------
so further test and I think the error comes due to radio and connect 2 - I have removed radio from can gateway list but it still shows on vcds dash as 56 radio. And potentially the error is there? Any idea on it?
