Ok - noticed a few lines saying "Trailer assist active" in the 5F.I don’t have trailer assist
A couple of questions re the ABS coding
The van is
SWB
big front brakes
ACC or normal CC ???
The van is short wheelbase, T32 so big brakes, and has ACCOk - noticed a few lines saying "Trailer assist active" in the 5F.
The van is
SWB
big front brakes
That's good - but obviously no new menu for TPMS?VPS_0x0B to infotainment and no errors have occured
Well, we don't know if the invalid data is actually the reason for missing menu.
Anyways, for the factory installed direct TPMS the ABS coding changes are - just to negate the changes to activate indirect TPMS.
Byte 0 bit 5 = 1Byte 6 bit 3 = 1Byte 8 bit 2 = 1Byte 14 bit 4 = 1Byte 17 bit 4 = 0
I’ve now changed the 5 settings in 03 ABS and the TPMS is showing as a tab in the head unit display, although there is no data displayed.That's good - but obviously no new menu for TPMS?
@Robert happy to try anything if it helps, or can satisfy your curiosityI never verified that, but I am curious if it would be possible to activate both TPMS on MQB.
On T6 both systems (indirect and direct) work perfectly side by side. Although exactly the same names in the settings menu entry aren't helpful.
I‘m meeting Rob (Ross Tech and Briskoda Forum member) tomorrow who has ODIS and is going to upload parameter file to TPMS, flash the HBA mirror and upload a different dataset to the PLA module to try and remove the EPB issue@Robert happy to try anything if it helps, or can satisfy your curiosity![]()
Yes of course, still have a couple of errors to resolve, will post current vcds scan when back home
Code:
Saturday,04,May,2024,16:02:37:60815
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZNH006670 License Plate: DU68AUS
Mileage: 38098km-23672mi Repair Order: 04/05/2024
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 20 29 39 3C 44 55 5F 65 69 6C 75
D6 D7
VIN: WV1ZZZ7HZNH006670 Mileage: 38098km-23672miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DNAA) Labels: None
Part No SW: 05L 906 023 JG HW: 05L 907 309 F
Component: R4 2.0l TDI H80 2670
Revision: N1H80--- CVN: F19C03D9F3218A0EA3C795CF64CF85E9A3C795CF43FB2DAA
Coding: 001900340344050800000000000000000000000000000000
Shop #: WSC 09107 004 1048576
ASAM Dataset: EV_ECM20TDI01105L906023JG 006002
ROD: EV_ECM20TDI01105L906023JG.rod
VCID: 76B5E8CC5849E54A7DF-8022
VINID: 9E606AAAA1D8A9E600006187007D68BD3B
No fault code found.
Readiness: 0 0 0 1 1
Address 03: ABS Brakes (J104) Labels: 7LX-614-517-V1.clb
Part No SW: 7LB 614 517 B HW: 7LB 614 517
Component: ESC_base H01 0800
Serial number: 08501132210616
Coding: 30552752C847EE8B0C5AE4AB13667726392324B8
Shop #: WSC 00012 790 00028
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
VCID: 3FDB4DE837F364026E9-806A
Address 08: Auto HVAC (J301) Labels:* Redir Fail!
Part No SW: 7LA 907 426 E HW: 7LA 907 426 E
Component: AC Manuell H01 0602
Coding: B03110000810030001000800504001050000000000011000800000000000
ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
ROD: EV_AirCondiBHTCVN54XT6PA_VN46.rod
VCID: 45D75F00552F3ED2245-8010
Rear air conditioning block 1:
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 2Q0 937 090 D HW: 2Q0 937 090 C
Component: BCM A0 Std+ H12 0954
Serial number: 01102117601614 Dataset Number: V03935350KN 0001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_BCMA0 207001
ROD: EV_BCMA0_207_VN46.rod
VCID: 333311D80BBBB0629A1-8066
Rain/Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: S5Y21M06D10H18M01S31
Coding: 0218EE
Driver door control module:
Subsystem 2 - Part No SW: 7L1 959 405 B HW: 7L1 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000051439750
Coding: 1F0007
Front passenger door control module:
Subsystem 3 - Part No SW: 7L1 959 406 B HW: 7L1 959 164 B
Component: FHSG_PSG 001 0002
Serial number: 00000000000051408103
Coding: 050007
Anti-theft alarm system sensor:
Subsystem 4 - Part No SW: 5Q0 951 172 A HW: 5Q0 951 172 B
Component: Sensor, DWA 005 0403
Serial number: 000000000ZL21138CMUD
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000049677542
1 Fault Found:
2055 - Courtesy Illumination for Switch (Terminal 58xs)
B133E 11 [00001001] - Short to Ground
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 60
Mileage: 38098 km
Date: 2024.05.04
Time: 15:49:28
Zusaetzliche Umgebungsdaten-Terminal 15 status: On
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: Not operated
Zusaetzliche Umgebungsdaten-OFF: Not operated
Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 C
Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
Zusaetzliche Umgebungsdaten-Position lamps: Not operated
Zusaetzliche Umgebungsdaten-Parking light left: Not operated
Zusaetzliche Umgebungsdaten-Parking light right: Not operated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 12.2 V
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 K HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0073
Serial number: 000150057322038 Dataset Number: V03935336AG 0001
Coding: 8271165941
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_EPHVA2CAU3700000 009055
ROD: EV_EPHVA2CAU3700000_010_AU37.rod
VCID: 58E98674B29DB33A4F3-800C
1 Fault Found:
12658704 - Databus
U1121 00 [00001001] - Missing Message
[Steuerger t f r elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 38098 km
Date: 2024.05.04
Time: 15:48:50
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Dataset Number: V03935335RG 0001
Coding: 2A04601B01FF8748949C815560509700000000000000000004
Shop #: WSC 00012 790 00160
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 43D341185B1B00E20A1-8016
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 2Q0 959 655 AD HW: 2Q0 959 655 AD
Component: VW22Airbag 016 0506
Revision: -------- Dataset Number: V03935338FP 0001
Coding: 8800C000000000007C0000CF008C40000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X_VN46.rod
VCID: 7F5B0DE87773A4022E9-802A
Address 17: Instruments (J285) Labels:| 7LA-920-XXX-V1.clb-SRI3
Part No SW: 7LA 920 941 A HW: 7LA 920 941 A
Component: KOMBI 202 8500
Coding: 27A50A822488260001882A0D4401000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009071
ROD: EV_DashBoardVDDMQBAB_VN46.rod
VCID: 3E2530EC30F96D0A65F-806A
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AL HW: 3Q0 907 530 E
Component: GW MQB High 524 5463
Serial number: 08062110802964 Dataset Number: V03935338SA 0001
Coding: 030100044F056A0000000058000F00010001070000000000000000000000
GVL: 014C3C0000000100C04090008002480000000000000000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VN46.rod
VCID: 79AFE3F069578A3210D-802C
Generator:
Component: 5-00-11-00-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 3G0 959 442 N HW: 3G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H07 0110
Serial number: PR6-0440036155215438
Coding: 2C0D00
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 7E0 915 181 N HW: 7E0 915 181 N
Component: J367-BDMConti H03 1052
Serial number: 77343301002105250133
Address 20: High Beam Assist. (J844) Labels:. 8S0-857-511.clb
Part No SW: 3G0 857 511 AK HW: 3G0 857 511 AE
Component: FLA H10 0010
Revision: AA001001
Coding: 040401E201000000000000
ASAM Dataset: EV_HighBeamAssisAU316 001004
ROD: N/A
VCID: 71BFDBD03127C272A8D-8024
No ASAM data for: "EV_HighBeamAssisAU316" (VN46)
Address 29: Left Light
Cannot be reached
Address 39: Right Light
Cannot be reached
Address 3C: Lane Change (J1086) Labels:| 2Qx-907-686-V2.clb
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0150
Serial number: 00000563861325 Dataset Number: V03935334PN 0001
Coding: A2A54640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15_002_VN46.rod
VCID: 392F23F029D74A3250D-806C
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0150
Serial number: 00000564886889
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 G HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7160
Dataset Number: V03935340DA 0001
Coding: 0306
ASAM Dataset: EV_SteerAssisMNB 002015
ROD: EV_SteerAssisMNB_VN46.rod
VCID: 46D5580C682935CA2DF-8012
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Revision: -------- Serial number: --------------
Coding: 0C9A020009200001
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
ROD: EV_HeadlRegulAFSMQBMAX_VN46.rod
VCID: 41DF4B10410712F218D-8014
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 3CN 035 869 A HW: 3CN 035 869 A
Component: MU-E-D-ER 720 0920
Serial number: 18052100021852 Dataset Number: V03935343RV 0001
Coding: 06570000AA00000041111101008002001F0000C60000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001044
ROD: EV_MUEnt4CGen2LGE_VW27.rod
VCID: 44D142045E1507DA33B-8010
4 Faults Found:
0512 - Rear Right Bass Speaker
B1067 13 [00001001] - Open Circuit
[Tieftonlautsprecher Kanal 1: Unterbrechung (DC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 38098 km
Date: 2024.05.04
Time: 15:48:51
Voltage terminal 30: 12.1 V
0517 - Front Right Bass Speaker
B1062 13 [00001001] - Open Circuit
[Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 38098 km
Date: 2024.05.04
Time: 15:48:51
0522 - Front Left Bass Speaker
B105F 13 [00001001] - Open Circuit
[Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 38098 km
Date: 2024.05.04
Time: 15:48:51
0527 - Rear Left Bass Speaker
B1065 13 [00001001] - Open Circuit
[Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 38098 km
Date: 2024.05.04
Time: 15:48:51
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 D HW: 5Q0 907 273
Component: RDKBERU30 H06 0010
Serial number: 30000000707352 Dataset Number: v09600047P6 0204
ASAM Dataset: EV_RDKBERU30 006001
ROD: EV_RDKBERU30_VW41.rod
VCID: 363528CC18C9A54ABDF-8062
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 5H0 907 383 C HW: 5H0 907 383
Component: Anhaenger H12 0058
Serial number: 000000000006247
Coding: 0100000202001300
ASAM Dataset: EV_TrailFunctGener3Hella 001012
ROD: EV_TrailFunctGener3Hella_VN3S.rod
VCID: 2E0500ACE0999D8AF5F-807A
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H18 0231
Dataset Number: 81A909460E 0001
Coding: 0123010103002017000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB_004.rod
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 282 HW: 5WA 035 282
Component: OCUGen3Low H14 0092
Serial number: 0000000105NVTD1 Dataset Number: V03935344U 0001
Coding: 06462000196818208005460160000607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_002_VN46.rod
VCID: 015F8B100187D2F258D-8054
1 Fault Found:
1572115 - LTE Antenna 1
B17FD 13 [00001001] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 38098 km
Date: 2024.05.04
Time: 15:48:52
Voltage terminal 30: 12.2 V
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 992 941 571 AA HW: 992 941 571 A
Component: LED1L H08 9002
ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
ROD: EV_LLPGen3LKEBODPO68X_001_VN35.rod
VCID: 619FAB90E1C772F238D-8034
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H08 9002
ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
End----------(Elapsed Time: 01:42, VBatt start/end: 12.2V/12.2V)-----------
Hi @Pauly yep, all sorted and working as they shouldWhat was the outcome of these retrofits, did you get everything wrapped up ok in the end ?
