Sargent alarm
Paul Sussex
Hi
I have an alarm going off on the Sargent panel when plugged into EHU and charger switched on.
Beeping and flashing green light at top right - stops when disconnect EHU (which was connected to house socket - only way to stop it).
Charger is EC155 and controller EC50.
It also has a solar panel with MPPT controller.
Battery voltages (across terminals):
- leisure battery 13.64v
- starter battery 12.42v
Does this show both batteries are health and full charged?
MPPT is running at the same time and shows:
- 112 Kwh
- 21v (that sound a lot)
- 2n
Any ideas why the alarm goes off, I can see that would be annoying on site if sleeping (us and anyone around us)!
Sorry if this is a stupid question new to campers and how this should work / when I should plug stuff in / charge.
Thank you in advance.
Slow day at work.
Is the red charger switch on on the Sargent box?
Mind you I’m frequently on hookup with solar and the Sargent both charging without any issues.
Off to Weymouth next week with EHU and the leisure battery will have run down a bit as fridge will be on and 140 miles so will see if the charger starts alarming.
Should I only put the charger on when it needs charging or leave on all the time?
Sorry if this is a newbie stupid question,
