Hi all, months ago I started to get random side assist not available messages on the dash. After 2 days the system was dead.
Obdeleven s an came up with the rear right sensor at fault. I read several posts stating calibration needed for a new unit but a used unit can be swapped and no need for calibration etc.
I order a used unit online, that turned out to be virtually new . I had a failure message of " no basic setting" so assumed it was because the unit was new.
I ordered a definitely used unit, but that's the same, resulting fault of no basic setting. Fault code is C111554 and the fault is static.
I have driven hoping it might recalibrate and detect motion but no such luck.
I'm suspecting it's not the sensor unit at the back ofbthe van that's at fault , but rather a higher control module.
I guess I'm limited with obdeleven of how much I can troubleshoot so any ideas or tips greatly would be greatly appreciated.
Thanks !
Thanks !
