Slider door not opening on key fob
Similar problem. Central locking not releasing the sliding door lock and random door open messages on the dash, despite not having been able to open it in the first place! Gently patting the door lock area whilst holding the unlock on the key fob will usually get it open. Booked in at VW Stoke on 12th April.
I took out the latch & cleaned the switch.
cleared that problem, but currently can’t lock all the doors from the inside. Works great from the key fob, so will hopefully find a fix for the new problem
Had this today on my 2016, took the door card off from inside, drilled little hole in the latch mechanism and flooded it with penetrating oil and left it a while and now ok, had to do this lots on vws over the years I think it’s got a lot to do with the grease they use it goes claggy but also they do get water ingress it’s an easy fix but dealers will say it’s the latch, just make sure you seal the hole after I do it with a dollop of rtv
8 out of 10 times neither the fob nor the interior handle will open my slider. The big square plastic knob on the inside which you push down to lock the slider is not popping up when I try to unlock. So considering giving this a try. When you say you "flooded" it with penetrating oil, roughly how long are you spraying for? 5 seconds, 30 seconds or....? Thanks, Paul
Mines done it since I’ve owned it, what i do is, i hit the unlock button on the fob and then open the handle split second after, that way it unlocks. Though I will probably take it apart
I've just done this on my T6 Caravelle. One of the sliders is (was) reluctant to unlock.
Getting the trim off was a pain, and scary, I did it without trim pliers/tools, used a substantial flat wooden spoon from the kitchen which in retrospect was a false economy. I didn't break any clips (yet!) but the clips are all stuck in the door so I have had to order trim pliers anyway to remove them and re-insert on the trim side ready for putting the trim back on. I pulled the trim off enough to be able to access the latch mechanism with my drill, to be honest I'm not sure I could have removed the whole trim anyway!
I resealed the drilled hole with insulating tape. Fingers crossed it will works..... Will report back.
Well 2 weeks later, and my slider has been reliably opening 100% of the time! Great.
Refitting the trim was fiddly but not too bad.
So I recommend this fix if your slider problem is that the door is not reliably unlocking.
Hmm. I had to unlock 3 times to get the slider to open this morning. :mad:
Thanks for the above advice Niknak!
My door has been getting worse over the last 12 months and this weekend it wouldn’t open via the key fob or the internal handle.
Followed your instructions and it’s now 100% fine!
Just wished I’d done it sooner.
Phil.
Dreamy! This worked for me :)
Thanks @Niknak !
The side door on my PV started to not unlock as per everyone else in the thread. It would take several attempts, and on the 5th or 6th might finally unlock. It's been like that for months. It then failed to unlock at all last week. I opened it this morning by using pliers on the internal button. I drilled the hole as directed by our dear departed @Niknak, gave it a liberal portion of WD40, let it soak in while I made a cuppa, and then exercised it a few times. It worked first time, every time. I've given it some more WD, and put a rag it to catch the drips coming out from the cable.
Awesome, easy fix. The forum delivers again. All done by 10am on a Monday morning. :thumbsup:
Great but please use any other lubricant with no aggressive ingredients.
WD40 is amazing for rusty bolts/nuts but not for precise mechanics and electrical switches/contacts.
Agree it works as a quick solution but in long run cleaned contacts are exposed to accelerated corrosion and effectively premature permanent failure.
Don't diss the WD. It's been good to me over the years.... My old dad even used to polish his car with it. Or 3 in One for extra shine. :cool:
CRC 5.56 any good?..
Just done exactly the same and fixed straight away - now locks and unlocks on the button (literally) thanks @Niknak (if you ever come back!)
Thank you Niknak! I did this over a month ago after is got as bad as 50/50 if a side door would open from the outside on my T6 and the latch has worked faultlessly since. I bought a can of GT85 from Screwfix and did not need to drill a hole into the mechanism on mine as there was several gaps around it.
I would not attempt to get the door trim off if you have a Caravelle without any trim pliers.
Latch has still been working faultlessly but noticed the door card has been rubbing on the wheel arch
Ordered some new clips and somehow managed to stop the door just a few inches open and the door card went on so easily compared to to trying to use the old clips and having the door closed.
Same problem, same fix today.
Getting the door panel back on was a pain. The part below the handle trim - took a lot of force to get it back under.
I've had the same problem on my 2012 shuttle and managed to remove the door trim today. Somewhat of a bugger of a job, as it has to be done with the slider partially open and the side towards the rear of the van is really tricky to get to. But I managed it none the less.
I prised open the actuator (broken the little clip) and flooded it with WD40 Dry PTFE... hopefully that will sort it. It works for now, but will wait for a colder day to see if it is a permanent fix.
On removing the trim I found that one of the thin lateral welds that hold the door skin to the frame was broken along its length?
Something to worry about... or not?
This thread has been very useful, and for anyone attempting this job, please look at the below picture as it gives a good idea of where the trim clips are located...
Mine does it as soon as the temp drop below 0. Also sometimes it needs a double unlock on the key fob in warmer weather, very frustrating!
This as a lot to do with it below 0 not a chance sun warms the panel of the door as if by magic open,i'm trying my best to park with the door facing the sun.
Going to try the lubricating idea tomorrow,once the sun comes up.......... no problem in the warmer weather.
Thank you NIKNAK just done this,cured the problem SIMPLES.
