They look good where about did you get the panels and trim from please
Right...I've hit a brick wall!!!!.......I didn't realise that only having a single sliding door would be such a pain....I went to mock up the caravelle door cards and realised that the 'panel' side window is a different length than on a sliding door...I assumed they would be the same....so now I have 2 pairs of door cards, one caravelle and one shuttle that I can't use.....
I'm tempted to cut the shuttle ones up to make a single door card for the panel side...for example cut one in half, measure it up the and cut a 2/3 inch strip out of the other side and try to bond this together and recover .. a lot of work but will solve the problem and at first glance the appearance would be the same.
Unless anyone is aware of a OEM trip panel off another model (multivan/shuttle/caravelle) that fits a single sliding door model?
Cali Campers in New Milton, i believe.
@T6180 did you remedy this? That Hinckley £200,000 show camper had a single slider with OEM panels, I’m sure, so they must have found a way around it.
Also, was your van a PV before? Is your window OEM or aftermarket?
I ask as I wonder if these trims will fit a sliding door with aftermarket windows (what with all those clips).
All change..it has a knock in effect.. pillars mean roof linings too.. door cards and window surrounds are fine together but as soon as you do pillars you open a can of expensive worms.If you use the Caravelle interior do you have to use the Caravelle pillars tops too or do the Kombi originals still butt up ok?
@Montecha who trimmed your seats they look lovely, do you have any details please.
Yes looked them up but nothing, there is someone local to me here so will give them a call after xmas holsIt was a company called 'the trim guru' in Coventry but I think they have stopped trading.
Do you have a template for drilling the holes for the top trim anywhere please? I've purchased a panel, window trim and lock trim I just don't want to bodge the holes... Thank youSorry about the crap photos. its very hard getting a decent photo with the seats in place
