Well I will keep an eye on it, since the weather has got warmer it's been a lot better, eventually got my new bigger Bosch battery today so just put that in, will see what happens!
My 66 plate T6 is really struggling to crank ...new battery , new starter motor , battery voltage is 12.3 , charging at 14.7....i'm lost .
I drove it for an hour today ,stopped , tried to start it again and it wouldn't crank at all. After half an hour it fired up fine ...desperately need some help or advice
Check the positive to the stater. Remove the cable and check the impedance. It could be you have corrosion within the cable that you can’t see.
This is not unusual when the cable gets wet it degrades the cable resulting in a poor connection .
