Clean it out, that's what I do
I’ve experienced this too. I’ve been told by the dealer that it’s quite normal and is caused by condensation. As others have mentioned you only need worry if it appears on dipstick when checking the oil level. I think they said it’s common on engines with an EGR.Hi Guys new to the Forum
Found the fan running really hard after a short journey today.
Checked water levels fine. Dipped the oil and it was to the lower end of dip stick.
Went to top up and found the Mayo stuff on inside of filler pipe.
Will take it to main dealer on Tuesday when they open after Easter.
Hope not to serious as only done 1K in 2 weeks.
Thanks for your postings some sound serious some sound like nothing to worry about.
I was cleaning and checking my oil filler cap and cleaning mayo every time but seems to have stopped now. Van now 12 months old mileage 2,565 but none short trips !I've had my 150 dsg from new six months ago. It's approaching 10,000miles and as i planned to change the oil and filter at 10k i thought i'd open the oil filler cap for the first time. When i saw the thick black sludge in the filler neck i was horrified!
I don't make any short journeys, the temp always gets to 90 when driving, no loss of fluids or oil so I'm surprised to see this.
The dealer assures me this is 'normal' but i'm not impressed, surely vw need to modify the engine so it breathes better.
Now I've read on here it's a common issue I'm not so concerned, i'll just have to clean out the filler neck often and maybe drive harder to see if itmakes any difference.
Having the oil and filter changed tomorrow☺
To be honest with you so was i. I got st8 on here to see if anyone else had same issue and found it was common. Not convinced but nothing we can do !I'm amazed to see oil caps with that sludge .... it reminds me of the bad FIAT oil that was used in the 70s in cars here in Italy ... but with current products it does not have to happen ... even the history of condensation does not convince me .... have you tried with the engine on to remove the cap and check how much vent? .. if affirmative means that water comes from the head gas ...
Don’t bother just clean itout and get on with your day.Just checked my filler cap and its got mayo! its a 2018 Edition 150 I'll ring the dealer tomorrow and check it out, dip stick looks fine, I've got under 3,000 miles.
