Attached to post 13 So I looked in the engine bay..and then the oil fillerI found this thread but not the TSB?
Ps im a new member
Back in the olden days, the Vauxhall Viva 1256HC used to suffer from this. The cause was cold air coming through the massive engine bay over the radiator, and cooling the rocker box, causing condensation in the oil and mayo inside the rocker box and filler neck. The fix was to make up a tin deflector plate, secured by the thermostat housing bolts at the front of the head to deflect cold air around and away from the top of the motor.
That was in about 1980 though... generally most things have moved on since then.........![]()
No, see previous responseI have just checked mine it’s the same it’s like jelly on the dipstick really worried about driving it now. It’s so jelly I can’t really tell what the oil level is. Is it drivable ? I do short journeys but it’s so thick it won’t even drip off the dipstick. Should I not drive it?
Thank for advise Pete I just went and dipped oil it does start to become a bit better but dipped more than 4 times tbh but it was not as jelly as before. I will ring dealer mondayTry checking the oil level several times, cleaning the dipstick each time. It might be that you are picking up emulsion from the dipstick tube, and eventually you get a dipstick with clean-ish oil.
If after say 4 attempts, you still get emulsion, then there is probably a bigger issue, and you must not drive the vehicle.
Pete
