One way to prove or disprove this, would be to hook the gas detector into a separate 12volt battery, not connected to the vehicle, leaving everything else as is.. And take it for a run.. But I'd still fit a DC to DC smart charge system in place of the bcm relay affair.. But that's just me..Maybe the voltage spikes are upsetting the gas detectors..
I know .. sadly the Ring unit is too big for my set up .. when do you have the EL1230 back in stock @travelvolts ?I suggest that you go for the eLogic EL1230
Actually, I could have this situation with the actual starter battery. I was planning to have my solar panel trickle charge the vehicle battery in addition to charging the leisure battery.
Given this, we could be starting most journeys with the vehicle battery at 100%. Is there any danger of the alternator then harming the starter battery as the voltage rises under regenerative braking?
It is not advisable to charge the vehicle battery in this way (why would you need to?). This battery is monitored by the engine ECU and if you charge it by other methods than the alternator you could end up with the vehicle overcharging it.
