The manufacturers quote it has a current range of 0-2A. That implies a current limiting circuit.
Or are they just saying that they have a 7.5 ohm resistor so a a 15.6V leisure battery (worse case) to a 0V completely flat start battery (worse case) would result in 2A flow.
That would however result in 30W of heat that would need dissipating and a large 30W resistor. Something doesn't stack up between the hardware and the spec. You can make other assumptions about max and min voltages of course but there must be something more to limit current to 2A in that case.
Like to see the inside of one of these........
I haven't got one myself . . . . . but straight away i though something was up as there was no ground connection or 0v reference....?
so how could the circuit/charger work if it had no ground or 0v connection . . . . . it cant (unless it was just a passive pass through device)
so i done some digging and saw this review on Amazon . . . which confirmed my suspicion that it is just a passive pass-through device. (just a diode and a couple of current limiting resistors)
and yes me to, i would like to see one cut open . . . . . but i bet they have used potting compound to hide the contents?
https://www.amazon.co.uk/Votronic-b...2a+12v+dc+to+dc+battery&qid=1572188952&sr=8-3
John Smith
1.0 out of 5 starsMisleading
30 December 2018
Verified Purchase
Do not buy this device. Inside the plastic box is a single small diode and two resistors. This is not a charger in the normal sense of the word, simply a current limiting resistor and a diode to prevent reverse current flow when two batteries are connected together. It is absurdly overpriced.
