The ones I have are actually greyThey look great...
Might need something like this at spring camp.
I'll have a look around.
Thems the one I gotWe have these:
Fiamma Motorhome Anti-Skid Grip System is ideal for wet and muddy campground
www.agentfiamma.co.uk
Never used them in anger, but small enough to have just in case.
thats what i was thinking tooThey look great...
on orderI bought something similar to these when we got the ramps. Never used them but they sit in the van just in case using 0 space
Campervan Anti-Slip Wheel Grip Mats – Set of 2
These Maypole Campervan Anti-Slip Wheel Grip Mats have a high grip surface on each side for maximum tyre traction, ideal for getting your VW camperwww.funkyleisure.co.uk
They look like basic nylon or polypropylene rope, not very strong. Consider making your own using Dyneema or similar. Go to your local chandlery and buy some off-cuts, or roll ends. Use this guide to splicing
I've also ordered some of these.I bought something similar to these when we got the ramps. Never used them but they sit in the van just in case using 0 space
Me too, got them from Car Parts 4 Less £9.49 a pair, got 2 pairs to be on the safe side, also their Clim-air wind deflectors are reduced to £37.49.on order
Chandlery? Where do you live? 1800s?They look like basic nylon or polypropylene rope, not very strong. Consider making your own using Dyneema or similar. Go to your local chandlery and buy some off-cuts, or roll ends. Use this guide to splicing
Button knots and Diamond knots are discussed here and here
Also came back in here to ask this! We’ve got a set of the yellow ones under the RIB bed at all times but haven’t had to use them yet (fingers crossed!).General consensus; are these grip mats used just when you get stuck or do you park on them as a precaution?
I’ve got a set and they look very flexible.
We have never used them as never needed to use them, this may be because it’s so crap off road I’ve never got far enough off road to get stuck in wet conditions.Also came back in here to ask this! We’ve got a set of the yellow ones under the RIB bed at all times but haven’t had to use them yet (fingers crossed!).
Don’t think we can be towed because of our body kit if we ever get stuck
wow - thats well above my skill set.They look like basic nylon or polypropylene rope, not very strong. Consider making your own using Dyneema or similar. Go to your local chandlery and buy some off-cuts, or roll ends. Use this guide to splicing
Sounds like a good reason to go back to standard to me. Presumably that might also mean that you couldn't be recovered after a breakdown.Don’t think we can be towed because of our body kit if we ever get stuck
I parked on mine last weekend, I'm not sure I'd have moved at all without them.General consensus; are these grip mats used just when you get stuck or do you park on them as a precaution?
@middle-englander Do you have the light weight ones?I parked on mine last weekend, I'm not sure I'd have moved at all without them.
