You can’t run a standard tyre on solow and 20’s even at their maximum height. We have tried. Don’t even bother looking if you are T32 and want to run underrated tyres. Great suspension though and very smooth and compliant considering the drop. On 18’s you can run all the way down, and with correct tyres.
Lots of other options to get you where you need to be with that tyre and wheel setup- max low from Projekt sensitive will run you nearly as low - ( see our our thread on here)or even B14 Komforts, can sit pretty low 70mm or more dependant on your vehicle.
If you are local come over and have a go in one of our demo vans and a chat over coffee. We fit pretty much all of the available coilover kits and correctly hunter alignment it afterwards, which is critical with big drops. If not local then alway happy to advise on the phone or message.
