Hi, quick question for the electrics/solar experts on here. Currently connecting a Ctek charger up to the starter battery if I'm not going to use the van for more than a couple of days. This has the advantage of keeping the leisure battery topped up via my dc to dc charger. I've already got an mppt controller setup for a mobile foldup solar and was thinking it would be a lot easier to just install a panel on the roof.
Question is if I keep it as it is do I need to install an ignition controlled relay to disconnect the solar when engine is running and if so which side of the controller should it be??
