Steering wheel upgrade / Coding
albertinno
Hello. I need help with coding.
I installed a new steering wheel with the code: 2H6419091 and the steering wheel is missing gearshift paddles.
Then I also replaced the airbag wiring harness:
Then I connected the necessary wires to the BMC and also ran the power cable there.
When I started coding, I found two places where I added checkmarks:
I also found a place for the cruise control, which was already active. I have the cruise control together with the turn signal lever.
After coding, the situation is like this.
The buttons on the steering wheel and the horn started working. But the problem is that now the cruise control no longer works and the car gets an error that it cannot connect to the gearshift paddles on the steering wheel.
Now the engine light also started to come on and the dashboard shows that the cruise control is activated. When I press the buttons, nothing happens.
What could be the thing I should do to get this cruise control working and get rid of these errors.
Regards Albert
Am surprised no one has been in touch with this. I'm wondering if it has perhaps been covered in previous threads? See below thread suggestions)
I'm looking to install a new steering wheel in the next year or so and retro installing ACC so am always interested in these threads.
Hope you get it sorted - keep us updated
To understand what the van thinks about the installation please post
(1) An old VCDS Auto-Scan before any adjustments or installs were made​
(2) Current VCDS Auto-Scan​
(3) A blockmap data from 01-Engine​
(4) A blockmap data from 09-Central Electrics​
How-to create a blockmap data package​
VCDS > Applications > Controller Channel Map >
For "Single controller address" - use 01 and 09
Tick/fill boxes as above and click on Go.
There will be files blockmap-01-...CSV and blockmap-09-...CSV in folder C:\Ross-Tech\VCDS\Logs\....
Note: only VCDS HEX-V2 and VCDS HEX-NET cables have the capability to create blockmap files.
Like an honorableand courageous knight riding out of the mist with an unsheathed sword of knowledge! #swoons
  • Love
