Sterling Pro Batt Ultra To A Cbe Pc180 Ds-300uk
hyk
Hello all
please could someone let me know if i have made the correct assumptions for adding a Sterling Pro Batt Ultra to a CBE PC180 DS-300UK. The vehicle is a T6 EU6
having read some previous posts hopefully i’ve understood correctly:
  1. vehicle battery +ve and -ve connect to the Sterling B2B Unit
  2. Sterling B2B Unit +ve connect to Leisure battery
  3. -ve from Leisure battery to vehicle battery -ve
  4. Leisure battery (B2) +ve with 50A fuse to 12v distribution box (DS300UK unit)
  5. ignition feed connected to DS300UK
  6. vehicle battery +ve to DS300UK - not connected
  7. R37 resistor disabled (one leg cut and sleeved) to remove the battery relay, this being replaced by the Sterling B2B charger.
i still want to use the CBE system battery charger with the 240v connection.
thank you in advance
