Ok so there are a lot of threads about stop start and I have seen lots of information but I am hoping some of you much more technical people can point me down the route of the correct thread.
The van is a Motability vehicle and so I cannot go poking around to look for things and also I think if I did get down there I wouldn’t be able to get back up again
so thought I would tell you what has happened in the hope that you can guide me.
The van recently went into the dealership, it was working perfectly, for its first MOT, an auto gearbox fluid change and also brake fluid change. The car passed MOT with no issues at all. Anyway when we picked the van up the stop start was no longer working. We called the dealership and it was another 2 weeks before the could get it in. They have said they tested the battery and the alternator and they passed fine and they can’t see anything wrong as it worked fine for them in a test drive.
Ok so we picked it up and on the way home the start stop is not working again. We have tried turning everything off as we drive, have set the air on at the normal 21C (after reading some posts) then turned it off, turned the auto lights off, turned the radio off and even unplugged the phone so that wasn’t charging. Now call me a conspiracy theorist but for it to work perfectly for 3 years and then for them to be working around the engine whilst doing the gearbox fluid change and it not to work seems to ring alarm bells.
What do you clever techs people think they might have damaged or left unplugged when doing the fluid change? It is odd they claim it works when they do a test drive but when we drive it normally (same way we have for the last 40k) it just refuses to work and we get that annoying A in a circle on the dash.
Thanks for taking the time to read all of that.
