I was hoping somebody might be able to give me some information regarding the below. On start up monday morning the coil light started flashing followed by a very rough idle, I think a cylinder down as the shaking and noise was pretty harsh. This has happened once before but when taken into a garage it would'nt repeat the issue. Both times the weather has been very wet, garage pointed to the weather as having brought the issue on, hence why it would'nt repeat as it had dried up by then. Not a moan about the garage in anyway as i was not charged even though they'd looked into water ingress in the fuse box under the battery to no avail - ie bone dry. I'm hoping it could be a loose/degraded wire perhaps, something that is shorting when its damp?! however i thought i'd post here and see what you guys thought. If its more complicated than the above it will be going back to the garage for further inspection. If its something i can look at myself over the weekend maybe someone could point me in the right direction. I'm no mechanic by a long way but willing to delve into some simple removing of parts to gain access to a possible wiring issue as i am competent in that area.
thanks in advance to anyone that takes the time to read and look
Code:
Monday,31,July,2023,06:17:22:04173
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WV1ZZZ7*********** License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 09 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7********* Mileage: 244790km-152105miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXGB) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KA HW: 04L 907 445
Component: R4 2.0l TDI H02 6163
Revision: 23002001
Coding: 00114010430401090000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KA 004012
ROD: EV_ECM20TDI03004L906056KA.rod
VCID: 76B5ED5B9846396BE53-8022
VINID: 9E606AAAA1D8A9860008304000E555785E
2 Faults Found:
25796 - Body Control Module (Central Electric)
U0140 00 [047] - No Communications
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 31
Mileage: 244040 km
Date: 2078.01.16
Time: 08:41:18
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 29 °C
Intake air temperature: 18 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 12.085 V
Unlearning counter according OBD: 40
Accelerator pedal travel: raw value: 0.00 %
CAN status - engine control module: 0
Cruise Control System (CCS): status: main switch off
selected gear: Shifting process active
30802 - Supply Voltage for Fuel Injector Group B
P2149 00 [175] - Open Circuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Mileage: 244795 km
Date: 2078.01.31
Time: 06:03:28
Engine RPM: 1200.75 /min
Normed load value: 60.4 %
Coolant temperature: 21 °C
Intake air temperature: 15 °C
Voltage terminal 30: 14.070 V
Mean injection quantity: 15 mg/stroke
Rail pressure regulation: status: Regulated oper. via press. ctrl valve and quant. ctrl valve
Fuel high pressure sensor: actual value: 492.0 bar
Control Module temperature: 21.0 °C
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 41556000000227
Coding: 517E4098256484818A760276A48221E6790000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB487FF7FCB823F65-806A
No fault code found.
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 14061613470217
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F57BB076712BBD3-802A
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 187161459
Coding: E0A4303A0A212031002009642E2B9C500F00708F60464DE0320400220800
Shop #: WSC 02737 022 109593
VCID: 2A0D092B1CFE2D8BB1B-807E
Subsystem 1 - Part No SW: 7E0 959 801 P HW: 7E0 959 801 P Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 0653
Serial number: KU0KU005071661876002
Coding: 1400B0
Subsystem 2 - Part No SW: 7E0 959 802 P HW: 7E0 959 802 P Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 0653
Serial number: KU0KU023061661755285
Coding: 0400A0
1 Fault Found:
03303 - Response Closing Status of Rear Left Door
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 26
Reset counter: 99
Mileage: 244040 km
Time Indication: 0
Date: 2017.12.06
Time: 08:50:40
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag021 H08 0018
Revision: -------- Serial number: 003V3001D9J-
Coding: 000000000000000000000000000000003231
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A2D396BECDE9D0BC1B-806E
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 960 S HW: 7E0 920 960 S
Component: KOMBI H03 1104
Serial number: 00000000000000
Coding: 750B010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 392F2667E9D89613C81-806C
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042305
VCID: 6889B323C272DF9B67F-803C
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1104
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DC92BDCFEED8B71B-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 L HW: 1K8 035 150 L
Component: MU-E-D-ER 055 7067
Serial number: 17061600012794
Coding: 06570000FF00000041111101008000001F0000C60000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW32.rod
VCID: 2E05053B209641AB6D3-807A
8 Faults Found:
0512 - Rear Right Bass Speaker
B1067 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 1: Unterbrechung (DC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 79
Mileage: 244040 km
Date: 2023.07.16
Time: 08:41:14
Voltage terminal 30: 11.8 V
0513 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 1: Unterbrechung (AC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 79
Mileage: 244040 km
Date: 2023.07.16
Time: 08:41:14
0517 - Front Right Bass Speaker
B1062 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 79
Mileage: 244040 km
Date: 2023.07.16
Time: 08:41:14
0518 - Front Right Treble Speaker
B1064 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 79
Mileage: 244040 km
Date: 2023.07.16
Time: 08:41:14
0522 - Front Left Bass Speaker
B105F 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 79
Mileage: 244040 km
Date: 2023.07.16
Time: 08:41:14
0523 - Front Left Treble Speaker
B1061 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 3: Unterbrechung (AC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 79
Mileage: 244040 km
Date: 2023.07.16
Time: 08:41:14
0527 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 79
Mileage: 244040 km
Date: 2023.07.16
Time: 08:41:14
0528 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 4: Unterbrechung (AC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 79
Mileage: 244040 km
Date: 2023.07.16
Time: 08:41:14
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 030B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75410903001606111808
2 Faults Found:
02252 - Generator
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 79
Mileage: 244040 km
Time Indication: 0
Date: 2017.12.06
Time: 08:42:13
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 119
Mileage: 244040 km
Time Indication: 0
Date: 2017.12.06
Time: 17:17:24
End----(Elapsed Time: 01:03, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)-----
