My two penny’s worth.
I read a lot of reviews about Steve at CRS Performance. Cannock is 40 minute drive away.
I read up on what I wanted to achieve.
Same height ‘ish. But I wanted comfort, like comfort that was derived from the best shock absorber for under £1500. Fitted.
I rang and spoke with Steve.
Detailed my requirements.
Arrived and they installed the kit, the height at the front was too low.
They removed all the front suspension again.
Micrometer adjusted the clamp and Shock.
Ordered thicker heavy duty too mount.
I bought us the sarnies, Steve picked up BEST !
Kit installed, Steve at CRS will detail better if I got it wrong !
H&R 30mm diameter front & rear ARB.
original Cali Ocean 6.1are 24mm front and 25mm rear. Woefully under rated IMHO for a 3 ton Campervan.
Koni shock absorbers on each corner, dual shock with frequency self adjusting technology.
Same technology they use in very high end
My review and findings below.
Before: sloppy and feels like it’s going to tip over, point it to a bend and worry the back is going to overtake the front, feeling like I’m driving a bus.
Bouncy castle effect feels like being on the venga bus.
Whilst driving at 81mph in France, feels bouncy and if you hit a large undulation in the road it’s just not the best feeling.
Pull out of a junction a little spiritedly, the front wheels can spin and lose traction.
After: taught steering, turn into a bend and the whole chassis feels like it sits down and is flat, with no roll, no feeling of wanting to tip over.
Planted going over speed humps, potholes, dips and bumps. No rattling or wobbling of things inside.
Whilst driving at motorway speeds, feels planted to the road, bends and undulating road surface soaked up and causes zero concerns, leaving one more relaxed whilst driving.
A more rounded enjoyable driving experience.
Lower only 20mm on the front height clearance, but gained a truckload of enjoyable driving experience. At 30mph on B roads, the idiots who pull out in front of you, causing you to jab the brakes, the whole body hunch’s down on its 4 corners rather than tipping you forward.
It’s like the suspension knows what you want, it’s hard when you want a quick manoeuvre. It’s soft and supportive like a good bra!! When you need it to soak up the bumps and holes.
Truly awe inspiring shock absorber.
It uses Koni’ patented frequency selective damping to ensure the correct level of damping on each corner as to the ever changing road conditions.
Another example, when I pull out of a road, used to get a small amount of tyre spin, and lose traction, tried the same junction, same wet greasy cold road. (I’ve still got the newish BFG K02’s on) And no wheel spin, it’s like the shock is holding the rear, no wheelie as the weight is transferred to the rear of the chassis, and I don’t get that lift up at the front anymore. Pushing the front down so more power is delivered and it’s a lot more noticeable for feeling stuck to the road.
The shock absorbers are truly a work of art.
The extra size diameter of the ARB will help in tandem with the shocks, and keep everything feeling tight and controlled.
That’s the feeling, tight, controlled, as if I am back in control and it’s going to go where I point it. And stay there
A truly massive Thank You to Steve (Steve’s!) at CRS Performance in Cannock.
Glad I went with spending money on suspension that £640 on Lazer lights !! Maybe next year
