I needed a couple of spacers, again a few quid from eBay and I bought a long security bolt from California campers I think@Cnud, that's a great idea and looks good too. Did you have to add some longer bolts and spacers on the other end that hasn't been extended? And did you cut away the plastic cover above where the wheel sits as well?
£245 - I'll be buying this one soon
UB Rear Door Spare Wheel Carrier V2 - VW T5 / 6 / 6.1 - UBERBUS Components
Spare wheel carrier for tailgate and barn door VW T5-T6.1. UB Wheel carrier V2- fitting instructionsuberbuscomponents.com
Did you get a chance to check the new OAL? Think I’m definitely going to get mine welded up. I don’t think I’ll need to weld any more height at the hinge end (I’m still 235 wide, same as my spare that came out). But given I don’t want to cut the plastics towards the rear I recon I need 1.5” or so to get around the wheel since it protrudes lower at that end.Nope, but I can drop a tape measure on it tomorrow if you want the overall length
Thanks. Going to take my plastic trim out first and see how I get on with that out (I’m 235/65R17) given how close it was on my first attempt. If that’s not enough then I’ll get a bit of an extension in. I think cutting the trim will make the largest difference. Given you are 245, are you on one of your extensions at the hinged end?It was 880mm overall length as I recall
Yep, using the first of my extension holes just to keep it all nice and parallel with the floor. If you take your trim out you may want to paint on some waxoyl or lanolin as it’s untreated where the plastic was.Thanks. Going to take my plastic trim out first and see how I get on with that out (I’m 235/65R17) given how close it was on my first attempt. If that’s not enough then I’ll get a bit of an extension in. I think cutting the trim will make the largest difference. Given you are 245, are you on one of your extensions at the hinged end?
No I havent yet. I do plan to but not got the spare cash at the minuteDid you go for this? Tempted to grab this and then the front runner ladder, for not a lot more money than the Siekel under mount. I need to weigh my spare however as it mentions a 33kg limit. Cheap option is still to copy the mods in this thread and just throw it underneath though. I don’t mind it being on my roof but it fairly eats into capacity so I can’t carry water or other heavy kit up there.
How does it fix to the door ? I don't understand ? We need to screw it to the door ???£245 - I'll be buying this one soon
I’m not on Facebook, but I’ve seen links to Volkstrek on there that looks like that:mmm too bad, there is no way to remove it after that without traces :/
Is there another solution for the two doors ? Like the solution there is for the T4 syncro for example...
Hi @BognorMotors ,We modify the standard carrier to fit a big wheel
We adapt the carrier as above to fit a specific size wheel - so whatever you want to fit, we make it to this size.Hi @BognorMotors ,
Please can you advise me on the spare wheel carrier on a t6.1 4motion.
Is it bigger to accommodate the original 17 x 7 steel spare wheel and if I fitted a 225/65 17 tyre, would it fit in the spare wheel position ?
What is the difference with your modified carrier?
Thanks @BognorMotors, I will contact you direct for more information.We adapt the carrier as above to fit a specific size wheel - so whatever you want to fit, we make it to this size.
