Nice!Kombi 2.0tdi 150 t32 highline bmt swb,
all VW accessories, showroom model.
Nice!
Couldn't help notice the tyre load rating. You will not pass a class 7 MOT test if it is indeed a T32.
They’ve done it before..Hmm interesting as the VW dealer fit the wheels and tires so I have no idea all I have is confirmation that all is VW accessories fitted by VW. I will definitely ask. Thanks for the info!
Surely they mean 3200kg, hence the T32 title.I have called the VW dealer was told I don’t need class 7 MOT as the T32 gross weight is 2200kg so it’s class 4 MOT. Tomorrow I will pop to see my friend who is MOT technician and will confirm that with him.
The final important factor when dealing with wheels is the load rating. The load rating of a wheel expressed in kilograms (KGs) is the maximum weight the wheel is rated for. This figure will be given in documentation for the wheel and also stamped on the inside of the rim.
The minimum load rating of a wheel will be half the given axle weight for that particular wheel but be aware that axle weight is not half of the vehicle max weight
eg a T32 (3200KG) has an axle weight of 1710/1720 KG so the minimum load rating would be half of 1720
= 860KG which is denoted as 103 on the sidewall of the tyre.
kg | kg | kg | kg | kg | kg | |||
Load index | Single | Dual | Load index | Single | Dual | Load index | Single | Dual |
70 | 670 | 1,340 | 110 | 2,120 | 4,240 | 150 | 6,700 | 13,400 |
71 | 690 | 1,380 | 111 | 2,180 | 4,360 | 151 | 6,900 | 13,800 |
72 | 710 | 1,420 | 112 | 2,240 | 4,480 | 152 | 7,100 | 14,200 |
73 | 730 | 1,460 | 113 | 2,300 | 4,600 | 153 | 7,300 | 14,600 |
74 | 750 | 1,500 | 114 | 2,360 | 4,720 | 154 | 7,500 | 15,000 |
75 | 774 | 1,548 | 115 | 2,430 | 4,860 | 155 | 7,750 | 15,500 |
76 | 800 | 1,600 | 116 | 2,500 | 5,000 | 156 | 8,000 | 16,000 |
77 | 824 | 1,648 | 117 | 2,570 | 5,140 | 157 | 8,250 | 16,500 |
78 | 850 | 1,700 | 118 | 2,640 | 5,280 | 158 | 8,500 | 17,000 |
79 | 874 | 1,748 | 119 | 2,720 | 5,440 | 159 | 8,750 | 17,500 |
80 | 900 | 1,800 | 120 | 2,800 | 5,600 | 160 | 9,000 | 18,000 |
81 | 924 | 1,848 | 121 | 2,900 | 5,800 | 161 | 9,250 | 18,500 |
82 | 950 | 1,900 | 122 | 3,000 | 6,000 | 162 | 9,500 | 19,000 |
83 | 974 | 1,948 | 123 | 3,100 | 6,200 | 163 | 9,750 | 19,500 |
84 | 1,000 | 2,000 | 124 | 3,200 | 6,400 | 164 | 10,000 | 20,000 |
85 | 1,030 | 2,060 | 125 | 3,300 | 6,600 | 165 | 10,300 | 20,600 |
86 | 1,060 | 2,120 | 126 | 3,400 | 6,800 | 166 | 10,600 | 21,200 |
87 | 1,090 | 2,180 | 127 | 3,500 | 7,000 | 167 | 10,900 | 21,800 |
88 | 1,120 | 2,240 | 128 | 3,600 | 7,200 | 168 | 11,200 | 22,400 |
89 | 1,160 | 2,320 | 129 | 3,700 | 7,400 | 169 | 11,600 | 23,200 |
90 | 1,200 | 2,400 | 130 | 3,800 | 7,600 | 170 | 12,000 | 24,000 |
91 | 1,230 | 2,460 | 131 | 3,900 | 7,800 | 171 | 12,300 | 24,600 |
92 | 1,260 | 2,520 | 132 | 4,000 | 8,000 | 172 | 12,600 | 25,200 |
93 | 1,300 | 2,600 | 133 | 4,120 | 8,240 | 173 | 13,000 | 26,000 |
94 | 1,340 | 2,680 | 134 | 4,240 | 8,480 | 174 | 13,400 | 26,800 |
95 | 1,380 | 2,760 | 135 | 4,360 | 8,720 | 175 | 13,800 | 27,600 |
96 | 1,420 | 2,840 | 136 | 4,480 | 8,960 | 176 | 14,200 | 28,400 |
97 | 1,460 | 2,920 | 137 | 4,600 | 9,200 | 177 | 14,600 | 29,200 |
98 | 1,500 | 3,000 | 138 | 4,720 | 9,440 | 178 | 15,000 | 30,000 |
99 | 1,550 | 3,100 | 139 | 4,860 | 9,720 | 179 | 15,500 | 31,000 |
100 | 1,600 | 3,200 | 140 | 5,000 | 10,000 | |||
101 | 1,650 | 3,300 | 141 | 5,150 | 10,300 | |||
102 | 1,700 | 3,400 | 142 | 5,300 | 10,600 | |||
103 | 1,750 | 3,500 | 143 | 5,450 | 10,900 | |||
104 | 1,800 | 3,600 | 144 | 5,600 | 11,200 | |||
105 | 1,850 | 3,700 | 145 | 5,800 | 11,600 | |||
106 | 1,900 | 3,800 | 146 | 6,000 | 12,000 | |||
107 | 1,950 | 3,900 | 147 | 6,150 | 12,300 | |||
108 | 2,000 | 4,000 | 148 | 6,300 | 12,600 | |||
109 | 2,060 | 4,120 | 149 | 6,500 | 13,000 |
Kind regards |
Wayne H. |
Service Manager VW Commercial Vehicles and SEAT |
The problem will be that the police will likely still report you, which means you taking a day off work to show the Magistrate that letter.Tomorrow I will pop to see my friend who is MOT technician and will confirm that with him.
Well I think they are wrong.. I phoned up cordwallis when I was ordering my t32 and enquired about the supermetal trident that VW are supplying as an offical accesory and was told that they are not for a t32... only up to t30... yuo can find it in the new accessories brochure for the t6.1.. you'll need 265/40/20 ( or 265/45/20.. its on this forum )... get the garage to stick som eon for you free of charge.Just received reply from VW dealer. The tires are satisfactory, and confirmed so if anything goes wrong I have a proof from VW.
Good afternoon,
I can confirm the tyres are satisfactory for the weight and size of your vehicle.
The vehicle as standard came with 17” wheels, the wheels and tyres currently on your vehicle are upgraded to 20”
Tyres need to be the same spec across the same axle.
Kind regards Wayne H. Service Manager
