Dealership or Manufacturer? Would a dealership lie?Yes but I haven’t fitted the wheels or tires the VW dealer has fitted wheels and tires. So who is really right?
let us know the size before they put them on. Ideally you're after a 265/40 for a T32 on 20s. They are readily available in 104 load rating. The fact the dealer is saying they're getting 107 makes me think they're going for an unnecessarily large size tyre, but it would be interesting to know.Hi so the latest update is that the VW dealership give in after I mentioned that I will get legal representative to look into the tires issue! Now they will be replacing the tires with 107 rated, not sure yet what size or make yet, they will let me know when the tires will be delivered.
That load rating is fine, you need minimum 103 load rating for T32. I'm going to take a guess that they're 275/40 size tyres.I read this thread and got slightly concerned as I am waiting to collect my T6 T32 which has 20" wheels. The sales guy has said the tyres are 106W rated, does this tick the box for the van and weight rating?
Passed the MOT yesterday with these fitted.
You are uninsured with these tyres. They need to be 103 for a t32. Your axle rating reflects this.Then I still went to different specialist tires garage I was told pretty much the same.
The 102 rated tires are all good!
Reason given the 102 rated are the highest level on 275/35r20!
And again there’s 10% on the weight ratio allowed!
And yes as above 265/40 is the size you want. Not 275/40
275/40 are OK. They meet the load rating requirements and as such are acceptable. They are larger than ideal though, so they'll have an effect on speedo accuracy, meaning that your speedo under reads slightly. A 265/40 also meets the load rating requirements, but is closer to OEM circumference size and therefore maintains greater speedo accuracy.just so I have this right, the tyres on my T32 should be 265/40 tyres and not 275/40?
Can you help me understand why before I collect my van?
Thanks from a van newbie.
I think Oli @BognorMotors was referring to the earlier posts and the 102 rated tyres that were being discussed there.@ChrisR what would be your suggestion be when I collect my van. @BognorMotors says I will be uninsured on the 275/40 tyres, so shall I ask the company who are selling me the van to change them to 265/40.
Seems I have a lot to learn re vans.
