T6.1 factory-fit aux battery wiring
Hi Pauly,
I have installed the second battery shutoff relay so hope that side of things are ok.
Would you please upload the wiring diagram for the harness for speed sensor
left front. for vehicles with anti-locking brake system -abs-. and. brake pad wear indicator.
7E0 927 903 K?
there is an ABS fault and a brake pad wear sensor fault. I just need to know where to check for continuity to check for damaged cables.
Thank you for your prompt response and the diagrams.
Just need a bit more help on the location of certain modules ad connectors on the van.
G34 -Front left brake pad wear sensor connects to TM -Coupling point in engine compartment.
If someone could give a rough idea as to where it is in the engine compartment please.
also, the G47 -Front left speed sensor connects to J981 -Electronic stabilisation program control unit..........where is this control unit located?
Any help would be much appreciated
I have an old copy of elsawin, but it is old and doesn't have any information for the T6.
So I managed to repair the loom. Was quite a bit of stripping down to do, but I managed to get to the snapped wiring and everything is now working as it should.
I had to drive few yards before all the fault lights turned off. Happy bunny!
I bought the VCDS HEX V2 that was most critical and worthwhile investment made, cleared all the faults and now its almost faultless.
I tried to google the backup Battery but couldn't find anything.
soon as I typed out this message, I remembered that i'd forgotten to fix a small cable to the positive terminal.........This may or may not have something to do with it.
I was also worried that I may have to get the calibration done to enable the ACC, But looks like there is no need for any calibration.
That alone would have set me back another £280.00
Again, Thanks for your help........ Much appreciated.
IMG_3502 2.JPG023263E0-BFFE-4309-99D8-8EB291E274FA_1_105_c.jpegA3948B01-0AFA-4C50-999A-78DF6901174A_1_105_c.jpeg
I managed to pull all the wires through the sleeving so I didn't have much heat shrink to cover up the bare wires.
Proper way to join wires.
80C0D7FD-4583-49DD-BD3B-44AC4B5F9CB8_1_105_c.jpegC21DEBF6-AB12-4BA5-917A-E9F1D54E2697_1_105_c.jpeg
As you may have seen, I decided to change the alloys from the riviera alloys to super metal Cell's with General grabbers. I didn't like the fact that they didn't fill out the wheel arches and looked like they were on rubber bands, so i'm much happier with these.
I intend to fit rear seats (1+1+1 and triple bench) so I thought these would be muh suited for a 8 seater shuttle when I travel to Europe next year.
i'm in the process of buying the brackets right now and getting them fitted following one of the build guides on this forum.
So I will install full sound deadening and 4 way stretch line the rear. I'll have to plan really well so will be seeking help from member foggy3061.
Seat brackets installed with support brackets by Philip .
Quite an involved job being a 4motion but Phil managed to make an amazing job of it.
I'm now looking for LWB shuttle roof liner with grab handles and lighting.
I have seen some on eBay but have to be careful of what I buy.
I'm liking the idea of the grab handles and the factory look.
Unfortunately I don't have climate control in the rear, so that may be a problem.
