Following on from my previous thread about installing a Golf R MK8 steering wheel
I had a heated steering wheel installed that wasnt connected so thought it was worth trying to get it working
I searched around for a compatible slip ring and soon found out the choices are slim so i took a punt and went for the slip ring from the same MK8 Golf R the steering wheel came from
Lets start at the beginning and see how its done, the above thread has details about removing the steering wheel so we are going to start from a bare slip ring
The top half of the steering column is clipped on and hinged at the rear, to remove it we have to start from the front and split the leading edge, i used the split on the left side to get a lever in and pop apart
then the top half will lift up and reveal the rear hinge
once you can see it you can see that you can pull the top piece forward and separate it
this reveals the two black screws on the front and the screw under the column by the column adjustment lever
with these out the lower plastics will come away
we need to unplug the slip ring
first you need to release the red plastic tab by pulling it down
then the black plastic tab needs to be pressed in to release the plug
with the cable unplugged the slip ring is ready to come off by removing the three silver screws
now your rocking this look
[Guide] T6.1 MFSW Steering Wheel Upgrade
Upgraded the MFSW on my 2022 6.1 to a Golf MK8 haptic touch wheel and want to lay out how i did it, lots of these steps are not specific to this wheel so thought this would be a handy 'how to' guide These wheels are a straight swap but the electrical connections are a bit different so a few...
www.t6forum.com
