T6.1 Horn Replacement - fit relay?
Tony2e
Hello. I have a compressor horn to replace the factory horn. Can I simply connect it using the wiring of the factory horn. Or do I need to go the whole way and run power from the battery with a separate relay? IMG_5073.jpegIMG_5072.jpeg
Hello. I have a compressor horn to replace the factory horn. Can I simply connect it using the wiring of the factory horn. Or do I need to go the whole way and run power from the battery with a separate relay? View attachment 240934View attachment 240935
Have a look at this How To Guide, they used a relay
Safe bet is to relay it back to the battery with an inline fuse between the battery and the relay that way you are double protected.
