Yes! Exactly! Shocking isn't itAre you saying that even though I've spent the equivalent of a mortgage on LED lights that the T6.1 fog lights are incandescent bulbs??
I hate the yellow driving lights as I’ve got the led headlights.
Not sure I agree as mine come on when I’m turning left or right to assist visibility in the direction I’m turning. Or from factory mine have been wired up wrongThey’re actually Fog Lights, not Driving Lights so it’s illegal to have them on unless visibility is below 100 yards.
Hi all, tried a search for led driving bulbs but only found suitable for t6 and older.
I hate the yellow driving lights as I’ve got the led headlights. Does anyone know of a direct suitable replacement that will not give me bulb errors?
Tia
A lot of manufacturers stick with halogen bulbs for their fog lights as LED’s are considered to be less effective in fog.
What?? That's a bit cheap isn't it... Nothing worse than looking at a vehicle that has a mix of LEDs and normal bulbs.
My misses Sportage as the full monty and it looks bag on..
Hmm, will have to set aside some more cash to get those fog LEDs in you link. Does the colour of the new LEDs match the headlamps?
Yes, that’s the cornering light function, but to have them permanently turned on is illegal unless visibility is below 100 yards.
I've no idea of the effectiveness of incandescent bulbs v led but I can say with some certainty that it looks far betterJust changed one for you earlier.. Here is the difference between the LED and hologen fog bulbs..
I
That's a seriously good looking front end!Just changed one for you earlier.. Here is the difference between the LED and hologen fog bulbs..
Try telling that to the drivers of virtually every Qashqai, Juke, Note, i10, i20...
And A3sNissan Puke drivers are particularly bad.
Have you got recent VCDS scan?Caution: Yesterday I was using the fog lamps (yes it was foggy) and at some point I get a caution symbol popped up on the dash... When I got to my destination I plugged in CARISTA and yes, fog lamp warning.. When I went to leave the warning had gone and didn't come back on the entire trip home with the fog lamps off, I'm assuming they were still working as cornering lamps! Need to check.
I will be in touch with Travelin-lite I think... Obviously somthing isn't right.
