Okay, I found what I think can cause this problem. My woes started when I messed about fitting the Black Vue dash cam. The f**king thing wouldn't stick to the windscreen properly, which meant that when it (often) came unstuck, I would angrily try to stick the damn thing back on. Once you push the top of the windscreen hard (mine is just below the rearview mirror) I would get the fault about SOS not working etc.
Being a clever kind of guy... I worked out, after this happening ten times or so, there must be some electrical connection in the area!
So this is what I've done, I pushed the windscreen down HARD on the outside (at the centre top) and touch wood, it's not happened again in 3 months or so.
I reckon that having a pop-top fitted can start this annoying process off, or make it worse.
I have no intention of messing about with this annoying fault again (unless it comes back) and hopefully, it might at least point someone else out in the right direction.
HI
New to forum also, something similar happened to me with my 6.1 three month after I bought it.
VW sent out a mobile tech who diagnosed faul, order part and came out next day and fitted it, so far so good.
