No but are made separate, I had two new ones fitted to my T5 because I was not happy with how it fitted after the first was bent. They will be batch produced and Sprayed the colour needed.
The roof is not part of the main vehicle production and added afterwards so may not get a normal curing?
Wow @Snowy55 you did kick the hornets nest with this one, the tread you started on the Cali forum is now up to 9 pages and still buzzing![]()
and some reports of poor mpg are a bit alarming.
Unless you are mercilessly ragging the nuts off it (which I doubt) thats not right. Someone had an EGR valve replaced and the mpg improved dramatically - could it be worth taking yours in to see if any fault codes come up? Or VAGCOM/Carista it with someone here? Definitely sounds dodgy to me.And on that note I'm now averaging 26mpg. Used v power the last 3 tanks and I can honestly say. No difference, however that's for another thread.
Tricky when you've been banned for daring to voice numerous issues on your old T5.1 Cali...Well known fault on the T5 California and it appears that the fault still exists on some T6 California's.
The Cali forum are collating data on this so please would all T6 Cali owners report to them too? After taking it straight back to the dealership if the problem is discovered of course!
Good advice, presumably any treatment, wax or otherwise will heed the same precaution?Ok, don't shoot me, not a Cali owner, but a note to all, if you take in for paintwork, and regularly spay silicone spray, please advise them, as silicone causes bad reaction to any paintwork, and travels a long way (you wouldn't believe how far), so will need a VERY good pre paint clean! As I say, please don't shoot![]()
