T6 California roof corrosion
So while soft/uncured paint doesn't exactly help, the root cause is bi-metallic corrosion. For those who know feel they're being made to suck eggs, apologies!
I agree with the bi metal corrosion for some of the pictures I've seen but not all of them, @Snowy55 pic with the tramlines just looks like a problem with the process and not allowing the paint to harden as @T6 Dave explained.
Plus I saw another one of the underside hinge bracket (was that you again @Snowy55) and that one just looked like a shoddy prep with paint only and no primer or etch etc.??
The T6 doesn't have those hinge brackets and looks completely different with a much larger bonded section that holds the bellows.
Maybe it's a bit of both - but our T5.1 was definitely almost all down to corrosion - usually it's the area around the front of the roof but often seems to appear around the entire roof section; we had the lot in ours but it still wasn't as bad as some. A few I saw looked truly awful and possibly structurally unsound.
So it would appear there are two causes for the corrosion of these rooves, paintwork as stated by @T6 Dave and bimetal corrosion as stated by @Polzeylad, both of which indicate a manufacturing defect that VW should be able to fix easily providing they admit that a problem exists at the manufacturing and or assembly point.
If only it was so simple - it's been happening since 2006 (when the first California was released) - 1000s have complained, VW has a big programme for getting affected vans re-done (usually doesn't work) but they've STILL got it wrong; arrrghhhhh!!!
Mine had all sorts of issues but I still miss it ever so slightly.
The S reg HM Coastguard Defender we use (owned by HM Coastguard) is still going strong; ultra low miles though.
Our S reg Coastguard Defender is still going strong; ultra low miles though.
Level of thefts (including some local - I had a dodgy character knocking my door a few weeks back) are detracting from the enjoyment of it and making me a bit nervous and paranoid about whether its still going to be there in the morning. Plus, with now having 3 vehicles between 2 of us its getting used less and less - even the snow they have been promising us all week has failed to arrive here!! :-) Have considered selling but know I'll regret it forever the moment I do!!
Always carry a full set of Timkin wheel bearing kits, and a spare stub axle kit for the front and back! :whistle::whistle::whistle::sleep::sleep::sleep:
200tdi, no electronic brain to give grief, and all the goodies on it, from 2 people I know to me... Just unreliable in the wheels dept, still F1 pit stop has nothing on my bearing changes!:grin bounce:Carry spare HD UJ kits, belts, hoses etc etc, it is a Defender after all!:uh run:
