Fuel Tank RemovalBump.... Is there an idiot's guide to dropping the tank? I only need access to fit and tighten the NS Cali rail bolts so was wondering whether it only needs lowering a tad?
Update: got the 2 brackets off nearest the slide door. Used the threaded rods (see pic) worked well. Dropped tank about 4 inch to get to the bolts tricky one was the one far left in the pic.Hi I’m struggling to understand what is needed?! I have the 4 brackets to remove from a triple bench. I’ve removed all the plastic on passenger side. I now need to lower the tank and I have threaded rods to support the tank. I do not know what I need to do at the filler cap end or anywhere else in turns of disconnecting or do I just lower? Can I get away with lowering one side? Thanks
Update... I finally removed the final 2 brackets. Had to disconnect exhaust starting at where the exhaust system has a join (see pic ) the joint was a bugger to unscrew do to rust. You’ll need to prop up the front part when you slide them apart (I just used a plastic box on its end). To slide them apart you need to undo the 2x2 bolts holding up the box mid van and the 2 bolts holding the back box (see pics). The mid box needs supporting whilst you unscrew. I propped to allow it to lower by 5 inch. Could then easily remove all heat shield fixings. I then managed to get hand (I have small hands) between the heat shield and underside of floor and unscrew the bracket nuts. If you can’t then it’s the brake cable likely stopping you as it still holds the heat shield in place. Goes back much quicker!View attachment 64532
