Thanks Rslad. Very interesting.Yes they are E marked.
Does the beam pattern have a shape to it when on low beam or is it dead flat? I’m trying to work out how it appears that one model works on both RHD and LHD.I’ve had them fitted for around a year now and no issues with MOT
It has the DOT beam pattern. I’m not sure how one fits all as they are definitely right hand drive and I see no way of changing.Does the beam pattern have a shape to it when on low beam or is it dead flat? I’m trying to work out how it appears that one model works on both RHD and LHD.
Maybe they see UK in the delivery address and send the right one? I ask because I’ve dropped the question in the AliExpress posts (as have others) but nobody has answered. Thanks Rslad. Good to hear it from a forum member.It has the DOT beam pattern. I’m not sure how one fits all as they are definitely right hand drive and I see no way of changing.
If I remember tomorrow I’ll get a pic of the markings on the lensMaybe they see UK in the delivery address and send the right one? I ask because I’ve dropped the question in the AliExpress posts (as have others) but nobody has answered. Thanks Rslad. Good to hear it from a forum member.![]()
These look awesome, definitely better looking than the THQ. think I will put them on my 2025 list. What LED bulbs are you using with them?
They are dedicated LED units so no bulbs needed. No DAB interference either.These look awesome, definitely better looking than the THQ. think I will put them on my 2025 list. What LED bulbs are you using with them?
Oh right now figured the would need a an LED bulb for the dip and main bean like the THQ ones.They are dedicated LED units so no bulbs needed. No DAB interference either.
E-markings:
Looking great mate! Which package did you go for?Just finished installing full LED headlights to T6 and here are some pictures. I bought the lights from Germany (lichter-profi), but lights are from China considering the markings. The lights were almost plug&play, all I had to do is change the central electrics coding from H4 to H7.
E-markings:
H4 vs LED low beam
Parking light
Turn signal
Low beam
High beam
Low beam
High beam + Lazer elite 18
The light output is from another lever comparing to the halogen lights, car shows no error messages and install was quick and easy. Costs were around 970 € incl. shipping, so much cheaper comparing to OEM LEDs.
I can try to capture some snowy outdoor shots with my phone once it get dark and if you like it.
Thanks lateski! Sorry to keep asking things my friend….which adapter do you need?I got these with dynamic turn signals and start up since these were earlier avalaible. I could have gone with the standard versions of these, but earlier access was the key to this purchase.
Here is the link to the exact product: Profi-lichter site
Ah ok! I’ve got a Christa so that’s cool! Thanks again and enjoy driving at night!I didn't get any adapter, because I used VCDS to change coding from H4 to H7.
If you have H4 headlights and don't have an opportunity to code the central electrics module with VCDS/OBDEleven/Carista etc., you'll need the H4 adapter.
Rogue ravage plus with Michelin Agilis. Really happy with them. Much better ride! 17” ROGUE RAVAGE+ 1200kg LOAD RATING | ROGUE ALLOY CO LTDLooking great mate! Which package did you go for?
