Has any one had this after hitting a pothole?
I hit a pothole at about 45 the week before last. One of those big ones that immediately loosens your fillings and makes you certain that the TPMS ‘low pressure’ warning will illuminate.
It didn’t, but I did immediately get a brake warning that said to check the condition of the rear brakes (or words to that effect).
The pothole was so severe that I even stopped to check if the tyre pressures visually, and can’t believe it didn’t crack an alloy.
Since then I’ve had an intermittent ABS warning, before getting the two mentioned here:
Error: ABS stabilisation control ESC
Tyre pressure loss indicator currently not available.
These have now become permanent.
VCDS shows it to be that rear nearside wheel that hit the pothole.
