Did you use OEM parts?This fixed theirs but mine still doing it?!
Besides the generic OBD code P164B, do you have also the VW specific code (see post #2)?
I'm afraid the way forward would be:
The answers are in this thread pretty much, if you still have an issue after replacing the parts then some additional data logging need to be performed to see whats still going on.I have exactly the same van and same issue..... T6 150 2016 (66) Hope some T6 guru out there can give us some hope.
Well it would depend on what tests they have done and what codes were showing if they scanned it. If they have done an oil pressure check with a gauge and done some tests then that would suggest its an oil pump issue not a regulator issue. An oil pressure issue can lead to an engine replaced.I'm just a little confused why my garage has suggested I need an engine recon before they have replaced the oil pressure valve. They have said the oil pressure gauge used when they dropped the sump suggested that there is an 'internal loss of oil pressure'. Does a decision not to replace the valve make sense in light of that information or are they just not sure what they are doing?
Well as seen as there is a high, low and a regulator and they have only replaced the high, i would firstly find another garage as it sounds like they dont know vw’s that well and then for the sake of £100 in parts plus your labour i would replace the regulator first and then see how you go!
Yeah thats alot better! I would have always investigated oil pump first as well before saying oh yeah its your engine thats gone. If the bearings had gone it would make an awful noise!!Thanks very much Sam. Just been to the vw specialist who recommend exactly as you suggest and will do it for us next Tuesday. Why the garage decides to share the life out of me with the recon suggestion before doing this I just do not know.
Garage hasnt reset the oil inspection light, nowt to worry about.Had a journey I needed to make yesterday and I now have an additional oil inspection symbol on startup. Seems a strange coincidence and it makes me more concerned about whether it’s safe to drive to the garage. Could this be a coincidence and it’s just happens to be due an oil inspection? Should the garage who did an oil and filter change last week have reset the clock in this thought? Help appreciated
Hi guys, so I have just bought a T6 2017 102 Blue motion 5 speed manual model with 80k miles on it, from a private seller. Sneaky sneaky people in Watchet Somerset!!! warmed van prior to me viewing and said nothing about their recurring fault upon a cold start!! Awful way to do business....Well as seen as there is a high, low and a regulator and they have only replaced the high, i would firstly find another garage as it sounds like they dont know vw’s that well and then for the sake of £100 in parts plus your labour i would replace the regulator first and then see how you go!
How about this link (post#23)Is this it??
Yes, correct. However, you should check their response to the oil pump PWM signal duty cycle - e.g. picture 4 in post#1 - by quickly flooring the throttle you should get a momentary high pressure switch closed.The engine running I have low pressure switch closed and high pressure switch open.
Engine off I have both switches open. Can anyone confirm same?
