Hi, I'm contemplating tackling the regulating valve when/if I can diagnose it as being faulty with the test @mmi mentions above.So, I changed the oil switch on the filter housing along with a new oil pressure regulating valve from local vw dealership, and good news, fault has gone.
Hi Bob, its underneath near oil filter housing. Engine doesn't need supporting its the support for forward / back motion if that makes sense.Hi, I'm contemplating tackling the regulating valve when/if I can diagnose it as being faulty with the test @mmi mentions above.
Any chance you could send photos of the location of the valve, and the mount you had to move out the way?
Did you need to support the weight of the engine when you moved the mount?
You mention "after finding correct tools", what tools were required? anything out the ordinary?
Bob
For future reference. Applicable to T6 EU6 engines.
Oil pressure switch - F1. Switch pressure 2.3 to 3.0 barOil pressure switch for reduced oil pressure - F378 (919-040)Oil pressure regulating valve N428 (906-030)
References:
Workshop Manual Transporter 2016- Engines: CXFA, CXGA, CXGB, CXHA, CXGC, CXHB, and CXEB, CXECNote: different documents for engines built before/after August-2018.![]()
T6 - 2.0 Diesel EU6 Engine Wiring Diagram
2L Diesel Engine With Start/Stop Circuit Diagram Covers Euro 6 engines CXFA/CXGA/CXGB/CXHA/CXHB Please check the history/updates tab, first release is for early T6s manufactured from June 2015, second release is for vehicles manufactured from...www.t6forum.com
2L Diesel Engine With Start/Stop Circuit Diagram Covers Euro 6 engines CXEB/CXEC Please check the history/updates tab, first release is for early T6s manufactured from June 2015 with CXEB engine, second release is for vehicles manufactured from...www.t6forum.com
Oil pressure switch for reduced oil pressure - F378 (green)
At the rear of the cylinder head above the turbocharger. Use a
small hand mirror if necessary as it is difficult to reach.
Oil pressure switch - F1 (brown)
In the (base of) oil filter housing
Oil pressure regulating valve - N428
In the neighbourhood of oil filter
More details how to remove >here<
In the graphs the status of oil pressure switches (closed/open) is combined to show oil pressure states. Thus value 200 basically indicates oil pressure somewhere 0.3...2.3 bars, and respectively 400 indicates oil pressure above 2.3 bars. Also graphed is control signal of Oil pressure regulating valve (this far only values 0/100% observed).
Each dot in the graph represents a data point in the recording.
Picture 1.
Picture 1.1.
Picture 2.
Picture 3.
Picture 4.
EDIT: picture replaced to show more "bumps"
The bumps 1 and 2 by just flooring the pedal quickly. The third by gradually (slowly) increasing revs - note no change in green/orange.
IDE00021 Engine RPM
IDE00497-MAS00627 Status of oil pressure switches-Oil pressure switch for high pressure
IDE00497-MAS00628 Status of oil pressure switches-Oil pressure switch for low pressure
ENG130437 Oil pump PWM signal duty cycle
VCDS Basic Settings - IDE00494 - Test of changeover of oil pressure valve
T6 Engine controller has a dedicated test to verify operation of oil pressure regulator. The test runs engine for 10 seconds at 3000 RPM and commands oil pressure to "high" full time of high revs (unlike normally just for a short burst seen in picture 4).
Picture 5.
If the test fails I would expect to see something else than - routine OK? Please report back!
I’ve got the same fault code and I’ve just carried out the basic setting as described and it did indeed fail.For future reference. Applicable to T6 EU6 engines.
References:
Picture 1.
Picture 1.1.
Picture 2.
Picture 3.
Picture 4.
IDE00021 Engine RPM
Picture 5.
A detailed example how to run and record the test (Basic Settings)
[T6_measured] 01-Engine - Built-in test for EGR
So it seems - inevitable P0401. Well, visited a VW garage to be tested - the van had accumulated 30 events in ECU's memory since July 2021 (since 20 months now). Eventually managed turn on the emission light at event number 31 - thus had a priviledge to have EGR flow tested. The result -...www.t6forum.com
- Attached a VCDS measurement setup file TEST_OIL_PRESSURE_REGULATOR.u01 - remove the .PDF extension so it will become a VCDS compatible .u01 file.
- Alternatively can also tick the parameters individually
Thank you very much for reporting! Really appreciated!I’ve got the same fault code and I’ve just carried out the basic setting as described and it did indeed fail.
Here’s a pic of the outcome. It did about 10 seconds at 3000rpm then gave this result and the flashing coil light came on.
I guess it’s time to replace the oil pressure valve.
No probs. Just working my way through the threads after getting the flashing coil light.Thank you very much for reporting! Really appreciated!
That sounds like it did full test? See below 30 - 40 seconds.It did about 10 seconds at 3000rpm
I did it whilst driving - 30 minutes just because it was my daily run. The idea was to capture normal behaviour for future reference. I think what can be seen in post#1 pictures 1-4 that the response is slighly different when oil is cold vs. hot.No probs. Just working my way through the threads after getting the flashing coil light.
If I do the VCDS logging as per your post is that done stationary or whilst driving? How long for? And will this conclusively point to the oil pressure control valve?
Thanks. I’ll give that a go tomorrow if I get chance and post the results on here.That sounds like it did full test? See below 30 - 40 seconds.
Anyways, I think that measurement data when and why basic settings fail on your van would probably help better to conclude possible culprit (would expect be different than in the picture above).
I just realized I didn't describe too well how to set up measurements for basic settings (in post#1)
Before launching the "Test of changeover oil pressure valve" you can setup a recording by selecting "Show measuring data" (down left)
and selecting the following
IDE00021 Engine RPMIDE00497-MAS00627 Status of oil pressure switches-Oil pressure switch for high pressureIDE00497-MAS00628 Status of oil pressure switches-Oil pressure switch for low pressureENG130437 Oil pump PWM signal duty cycle
Click "Log" and
Click "Start"
Now launch the "Test of changeover oil pressure valve" ("Go")
Finally "Stop" the data logging
Please see more detailed description about steps setting up measurement when doing Basic Settings here - especially the "(2)"
I'm more than happy to create the plots.
Can somebody briefly explain why the Transporter is equipped with solenoid activated oil pressure control valves?
IC engines have run high pressure and low pressure lube oil circuits for decades using spring loaded regulators without issues.
Introducing electrical actuation seems like a recipe for a major engine wreck in the event of a failure.
Everything is all about getting as much mpg and as little emissions from engines. DPF's are causing a significant dip in mpg due to the regens, so they are trying to shave off fuel consumption by any other means possible. Using thin viscosity oil, and ECU pressure management is just one way of doing it. Unfortunately, this is making engines extremely complicated, and introducing more and more things that can go wrong.Can somebody briefly explain why the Transporter is equipped with solenoid activated oil pressure control valves?
I had this. VW changed sensors and regulator twice. Then changed oil pump. But low and behold still coil light and start stop error. All oil pressures etc are fine after their tests. So still scratching my head. Drives perfectI'm in the coil light fault code 16056 spin cycle. Been around the houses now, high and low switches replaced twice, regulation valve , finally mechanics replaced the oil pump. There were fragments of aluminium in the strainer, took the old pump home and dismantled it, very worn surfaces, perhaps letting oil pass? Also small gouge on a port. Doesn't look healthy so glad to have replaced it. The wear looks like it should have a bearing at that point, rotating part wearing straight on the housing. Hope this is the fix! Thanks to VeeW services for the very quick turnaround for our holiday
What is part number for this or can you send me a link pleaseSo, I changed the oil switch on the filter housing along with a new oil pressure regulating valve from local vw dealership, and good news, fault has gone.
Interesting to see, the new regulating valve is a different design altogether, to note,View attachment 218923 sealing o ring weirdly is in a different place, with less ports than previous.
All good though! referring to original photo I sent of location, that is not it. The reg valve is underneath, pull front engine mount out of the way, its there, bit of a pig to get to, but done in 2 hours ish after finding correct tools.
t30 is what holds screw in for the valve itself.
Bit of a hassle to get to it, but all done now. And looks like its solved my flashing coil light. New part is vastly different in size, ports and sealing o ring location ( see photos ) bizarre!! but sorted
Told them about the coil light and fault and that it failed the oil pressure valve test.
Just to confirm - the VCDS test did say "failed" in August?Ran he VCDS test again and it completed OK this time.
