"EHU location & availability" clarification moving forwards:
I've updated the first post in regards to EHU and pasted a copy below.
EHU is available but limited. (There is 16 EHU`s that can have 1x Splitter each - so 32 EHU points max) - so book early if you want EHU.
EHU pitch location is on a "first come - first served basis", that means that you can choose your own EHU pitch location when you arrive onsite,
The only way to reserve a specific EHU location is be the first to get there, ie arrive a day or more earlier to secure that specific location for the remainder of the event/weekend/week. ( some will be staying the week )
All other locations will be allocated on a arrival - First come, First served basis (there should be enough to go around)
We need to highlight this point as the site will allocate a EHU location on your booking/receipt form when you book - as part of there booking procedure,
This however will not be you final location onsite - that will be allocation on arrival. . . . . . .
(this is due to us having to double up the 16 available EHU locations to 32 pitches and with friends and family asking to be pitched together etc the EHU pitch locations becomes very fluid as we try to accommodate everyone's wishes ( ie larger setups, smaller setups, closer to the toilets, disabled access, away from the fire pits, closer to the entrance etc etc etc - everyone's wishes are different and we try to please everyone when pitching )
so again, if you want a specific EHU location you need to be first to arrive (ie wed,thur,fri etc)
We will get everyone parked & setup as normal with a meet & Greet at the camping field entrance like normal
