What are you using ?Just my 2 pence worth.
As MBBSA shows above....we also use a free standing table.
Obviously foot, stand and table needs a place to live but it’s very versatile...
goes outside when weather good as can’t beat alfresco dining.
Great ill get looking.As MBSSA shows in his pictures.
Same foot, same post and just a rectangular veneered top.
Top spins on post easily so can move past it easily when in van.
Light so easy to move in and out of van for eating outside.
Very versatile.
I also had to cut mine down.Thanks @MBBSA managed to get the set today, looks like I will need to cut the leg down as it seems high when sat in the back. Also need to source a table top.
The standard leg is designed for the “hole in the floor” mount, hence being too high when on the tripod. We are tempted to get a second leg to cut down for use with the tripod outside.Thanks @MBBSA managed to get the set today, looks like I will need to cut the leg down as it seems high when sat in the back. Also need to source a table top.
You've done a good job of the top, looks neat.I also had to cut mine down.
I just got a cheap bit of plywood then sanded and varnished it about 5 times for the top. Made a few templates for the top out of cardboard and mdf to try out different ideas and ended up with that. Didn’t want anything expensive as the kids would just wreck it. As it turned out I’m really pleased with the finish.
I'm thinking of buying another leg myself, for the table that isThe standard leg is designed for the “hole in the floor” mount, hence being too high when on the tripod. We are tempted to get a second leg to cut down for use with the tripod outside.
I tend to go the other way and end up legless - could be the beer lolI'm thinking of buying another leg myself, for the table that is![]()
Thanks @Gavandi I've seen a couple on fleabay.Ours was done when we had it converted as part of the deal'
It matches cupboards etc.
A good chippy would do it for you as its only a laminated top with plastic edging.
Good luck.
So is it a HM requirement when you put in the required paperwork to change from Van to Camper/Motorhome that all converted vehicles such as VW transporters have a table that is a part of the vehicle, rather than carrying a table that can either be folded or rolled up ?
I questioned this with my converter at the time.
He was categoric that it was irrelevant.
thx, thead not related to the table holding panel though.Have a look on this thread, I'm not sure the area you've circled is used for fixing.
Sliding door card panels
I also agree that it is a bit of an irrelevance but the Guidelines/law around conversion include:-I’d agree that it’s totally irrelevant, we had a new British built Motorhome not long ago, with free standing table
