Thank you mate, can you recommend any good locking wheel nuts? The standard 17" steels didn't come with any.Yes they will be fine unless your using spacers.
I use the standard ones on mine from Duchy and have had no issues at all!I have some banded amaroks on order from duchy, will my standard wheel bolts be ok?
Try Tamar wheels they have sets on there.
VW T5-T6 35mm Radius Locking Wheel Bolts in Black plus Key m14 x 1.5 - Tamar Wheels
Locking Wheel Bolts – 4 x Bolts and 1 x Key. Top Quality Bimecc Italian Made Alloy Wheel Bolts Specifications: Thread: 14×1.5mm Thread Length: 35mm Seating: Radius Hex: 17/19mm Material: Heat Treated Steel Colour: Black For Aftermarket Alloy Wheelswww.tamarwheels.co.uk
I wouldn't bother with any tbh.
I guess these have gone already?And they are off.. they are sitting in the garage now.
So if anyone wants them or is interested in them message me. @fezza68 heres your heads up.
The tyres aren’t load rated and will 100% want to be changed as they are rubbish.. (I won’t let them go if your not going to stretch a tyre over them) got them just to see what the stretch was like and it wasn’t enough.
Spigot rings included
Nope.. still sitting in the garage.I guess these have gone already?
Finally got the van suspension sorted today so that it sits right on the steels, 80mm drop on the Koni H&R setup thanks to Steve and his team @CRS Performance. Van rides as good as it looks!
Cheers, 255/45 Eagle F1s, no rubbing at all@RedUn looking good mate, what size tyres are you running? Do you have any rubbing?
It will sit perfect buddy, I'm on the same set up with SoLows and they look and drive spot on. My wheels always get comments and at this rate becoming very rare.
