Tinkering with the Thermo Top Evo ECU & Combustion Fan
oldiebut goodie
T6 Legend
New Thermo Top Evo ECU & Combustion Fan - generic non VW software. I think that they are Generation 4 Evo ecus.
There are 2 with the part number of 9042048a
and 5 with the part number of 9037921a
Supposedly compatible with 9042118A.
Anyone interested in playing with one - swapping for your dead ecu? or? Removing the tie to the vans software? or?
I have 6 of these and I am wondering if anyone is brave enough to experiment with the transplant. As I only deal with the air heaters I don't have an oem heater to play with. Ideally you will have delved into these heaters before and have an idea as to what you are trying to achieve. If no-one wants to have a go I will have to get hold of a heater myself and play.
Your heater must have the exhaust gas temperature sensor as in 1st pic;
Hi I'm interested in one or all of these as either my fan or ecu is dead. It's the same model too. If available where are you based? Thanks
The software is not VW, so if you operate yours via the vans controls these will not work. If you operate yours with a Multicontrol or Telestart they will work - they still have the manufacturers 2 hour operating limit unlike the latest RV Evo ecus.
