Top tip for running cable
Roodedoo
I use this thin bendy rod thing to thread cable (this time for my roof mounted light bar) so I don't have to pull so much of the van apart.
I've no idea if this is normal behaviour, but there you have it!
It's new to me, just a brain wave but of course everything's been done before..
I find the best way is to do it backwards, poke the rod through from where you want the cable to end up, and see where it appears!
Luckily I didn't plaster van
Any bright ideas where to route the cables into the engine bay?
I was thinking to just drill and grommet that plate behind the battery. Probs with plenty of gooey stuff too
There’s some examples on here that’ll help
Got there in the end.
Electrics in the rain...
When you have an ex RAC van, it's a restoration project as well as a camper conversion!
Also if you need to run a shortish distance a long plastic cable tie will work well. In the past I've used plastic pallet strapping as well.
