Front 2 roof rail bolts where removed and sealed with Silicone today. Inside the back has been silent coated, and then a layer of self adhesive thermoliner/insulation. Was a bit dark for pics when I finished, but will do in the morning.
But yes, Im getting to the point where I need to remove the bulkhead. Im a bit reluctant as the cab warms up quite quickly, and Im thinking it will take ages with the bulkhead out.
Tomorrows job is to cut the 6mm ply that was in into fitted shapes for the panels and then drilled for the hidden fixings. Not decided if to buy a pre-cut ply floor or get some from B&Q and cut my own.
Then I will need to make a paper/cardboard template of the batons before the gold coloured floorliner is glued down.
Then the white Dacron and the mains hookup under the bonnet. Need to work out how to get the end of the dash and glovebox off first.
