I wouldn’t mind the ‘unwanted light’ on the dash, at least I’d know the lights were on because VW couldn’t be bothered to fit one.
Something that needs to be clarified regarding the new wiring loom is where the current to the H7 bulb comes from when used in conjunction with the H1 bulb for Main (High) Beam. I'd like to think that it's not all being fed from the Main (High) Beam circuit and that they will use a relay and separate fused feed from the battery (or a similar solution).
Our lights are made by probably one of the biggest oem vehicle headlamp manufactures in the world
They designed the loom, and they say it’s fit for purpose then that’s good enough!
With respect, the OEM manufacturers generally work to a specification produced by the customer (e.g. VW if they supplied headlights to the factory) and go through NPI and PPAP processes (amongst others) to unsure form, fit and function to specification (I used to do this for a major automotive company).
It is probably worth finding out more about the design from your manufacturer so that you can provide your potential customers with a more informed and meaningful response. I would personally use VCDS to keep both bulbs on so that it works as VW intended,
Thank you @Transporter HQ for coming on and putting the ‘nay sayers’ mind at ease. I researched your lights thoroughly and am confident of their improvement to my standards H4s. Apart from the light benefits I think they look ‘the bollox’ too so will be splendid on my vehicle.
Going on this weekend so will post up some before and after shots for those still curious about the lights.
+1
Did you go for black or chrome?
Mine were shipped today, so hoping they will arrive before the weekend and I can get them fitted too!
One problem with vcds though is that not everyone has got it, and two most people wouldn’t know how to do it
What we have done is tried to get a soloution which is the easiest for the customer which in this case is a loom
Now for the step by step guide
