Assuming you've got standard halogen bulbs coming from THQ then it's a kind of yes and no answer.If the brightness of the lights in the new V3 version are not as bright as I would like, would these be a straight swap out?
Spot on, and it will be far superior with the HID kit rather than the H7 bulbs.I have ordered the V3's with standard H7 bulbs. So I guess I can buy the conversion kit and have it fitted when the lights are installed?
Yes, the bulb itself from the HID kit is a straight swap....
....but no, because you have to find somewhere to put the ballast, canbus resistor etc, the stuff you see in the image a few posts ago.
As @dubber36 has said above, it's much easier to fit all that lot tidily when the headlights are out of the vehicle, but it's not impossible to do it when they're in, just more hassle than it needs to be.
How did you mount them. Double sided tape or similar?
Folks, I’ve the poor H4,s on my T6 and been looking to upgrade to THQ V2/3,
Does anyone with the V2’s and H7 bulbs notice a big difference at night from the H4’s or is it worth fitting the v3’s with led’s ?.
I’m not technical so the HID kit blows my mind, I’ll looking for the easiest solution to being able to see in the dark without spending £4500.
I’ve ordered them with the Osram night breaker lamps, how do these compare with the HID you are discussing? (I assume they are a different thing)
The HID will be so much brighter and a crisper whiter light. The night breakers are good as halogen bulbs go, but can’t get anywhere near the performance of HID.I’ve ordered them with the Osram night breaker lamps, how do these compare with the HID you are discussing? (I assume they are a different thing)
So the yellow right hand light is the Osram night breaker? Advertised as 3700k, I thought they would be whiter and lighter!
Unfortunately there’s a lot of marketing nonsense about halogen bulbs, well, all bulbs for that matter.So the yellow right hand light is the Osram night breaker? Advertised as 3700k, I thought they would be whiter and lighter!
