Tyre pressure warnings
Evening!
Over the last couple of days I keep getting tyre pressure warnings on my van. It’s a T6 running 20s.
The first time I checked and set the pressures to 41psi although all wheels seemed to be at a similar pressure. I’ve since set them to 41psi and each time the warning comes on I check the pressures and they are all almost identical, no obvious issues. I reset the menu each time I check the pressures
Is it a common issue? Or could it be something else?
Im due to drive to France on Saturday so could do without this!
Had a similar issue. I read somewhere (here?) that you have to drive 20km immediately after resetting the tpms. Did that and had no further problem. tpms on my van is not done with sensors in the wheels but but the ABS measuring different wheel speed which might indicate a low tyre pressure.
I had a similar issue on a Seat Leon. I think my issue was that the tyres were worn unevenly (one close to legal limit and one brand new), and some big changes in outside temperature.
I think these things meant the whole system was at the limit of its intended tolerances.
Pete
