unable to store tyre pressure
My kombi does not give me the option to reset. It shows a kombi on radio screen and i can select different tyre sizes but no reset option. Wheels does not have tyre pressure sensors. The tire light on dash stays illuminated. How do i reset?
If you can select tyre sizes on the screen then you have direct TPMS which requires sensors in the wheels
Thanks or your help, I tried a van ecu reset and this seams to have worked, I am not
getting tyre pressure warning light on when starting the engine.
I will update if I have anymore problems.
hi @vwcolllet
this happened to me yesterday :(
was just wondering if the eco reset cure it for good or did the dash warning lights come back...
thank you...
His last post said he paid £200 to get an ABS sensor changed :eek:
That's daylight robbery.
I’ve had 3 sensors replaced now only 1 original left.
Paid £260 to have 2 replaced last week
I have posted a guide on activating indirect tpms on a 6.1 so you will just need to figure out how to disable the direct bit
Removing the module and unticking it from the gateway installation list will get rid of it but you will then need to deal with any faults that arise before you activate the indirect system
