I’m also concerned about length of bed as it’s 170 in a swb so I’m going to extend the top of rear unit right up to the tailgate carpet, there’s a good 10cm + there
Sam that looks like the nicest u shape set I've seen in terms of quality. Where is it from? Cushions look the best I've seen also, luxury feel.Great work! Wish i had the skills to do something like this, i made my own metal U shaped frame which was really good but i couldnt find anybody to clad it so ended up going with an off the shelf U shaped kit as i was just fed up at this point. I like it but i wouldnt say it perfect, would have liked a longer bed and no back rests etc.
My frame and full size bed
The kit I've bought:
The units are from VanLuxe in Blackburn - VANLuxe Camper Conversions ltd and the cushions were done by Caravan Upholstery in Westhoughton - Home | Caravan UpholsterySam that looks like the nicest u shape set I've seen in terms of quality. Where is it from? Cushions look the best I've seen also, luxury feel.
I'm using 12mm ply with mine. Certain areas i'd have another 9mm of wood for the slats to level the rivets in the floor. Also bonded and screwed some timber to the side panels and finally if i'm still not convinced I have exposed various anchor points which have threads on them to be able to REALLY fix it down.Hi, anyone that’s installed their U shape setup?, is a 12mm ply floor thick enough to attach various sections of furniture? Or should 18mm ply be a better choice?, I will also try to use the factory tie down points if possible too
Ta
Where did you end up ordering your altro from? Just about to start looking for this as wellYes,most go for 12 mm, a couple on converters I asked locally said they use 18mm, maybe it’s quicker for them not to fix batons under the floor first?
Anyway I thought 12 mm might be a little thin for the screws so managed to order ‘ Rare’ 15mm marine ply, to give a few more mm and like you will use brackets on the 10mm anchor points where possible
and i used some 9mm batons under this, I glued/bonded everything down, no screws
Just about to attempt fitting the altro Lino today, tomorrow,driving down to Van furniture to pick up the flat pack u shape kit
Got my flooring and other bits from Mega Van Mats, it’s just laying out in the sun warming up, before I glue it down, it’s tough old stuff, fit it on a warm day so it’s more flexibleWhere did you end up ordering your altro from? Just about to start looking for this as well
Hi Murray, how did it go with the updated CNC plans, would you be willing to share them for a cost at all? I'm searching for a CNC machine local to me and to build a set as wellSam that looks like the nicest u shape set I've seen in terms of quality. Where is it from? Cushions look the best I've seen also, luxury feel.
That sounds good to me mate, can you tag me when you've got the plans an worked out how many beers were paying for? HahaHi all sorry for the delay. Yes plans I purchased needed some adjustments but pretty much good to go. My friend has them on his computer system at the factory. I'll speak to him this week. I paid a few hundred for the original plans. I'll maybe ask for a small fee to share just so I can get a few beers for my mate if nothing else.
Will drop a message in here when I've got them
Amazing Murray, thank you. Happy to contribute to the beer fundHi all sorry for the delay. Yes plans I purchased needed some adjustments but pretty much good to go. My friend has them on his computer system at the factory. I'll speak to him this week. I paid a few hundred for the original plans. I'll maybe ask for a small fee to share just so I can get a few beers for my mate if nothing else.
Hi Murray any updates I’m ready to fit out wanting to go u-shaped cheersYeah it's making these standard plans work when we are all different heights. I'm 6ft so want to try and get the seating height and bed length just right. So I don't mind re cutting and trying different things.
It has to be comfortable to be useable. I've read lots about people spending 50-60k on top spec campers only to find out they can't sleep a wink on the rock n roll beds.
Will keep this thread updated as I go
Thats my converting with u shape bed I wanted that set up instead of rnr bedThought I'd share my attempts at a self build U shape bed system.
After a bit of hunting I found some CAD plans for sale on Ebay. Images were limited but seemed to show the U shape system very similar to that of Van Furniture etc.
I am fortunate enough to have a friend with a business and a CNC router and so the plans were passed to him.
We decided to initially build in 15mm ply. We weren't sure how good the CAD plans were and this would give us a budget version to see how it fits.
The eventual plan would be do go for 18mm buffalo/hex ply.
The plans have been an OK starting point but far from the finished article! We are in the process of re measuring/designing panels to ensure a perfect fit (or as good as!) The sliding bed panels are the wrong size (500mm on plans but should be 547) so we will need to re cut.
I've attached some images of the first fit and will update with more images as we progress. The kitchen unit is not in position as leisure battery and electrics sitting behind until i reposition
View attachment 187870View attachment 187870View attachment 187873View attachment 187874View attachment 187876View attachment 187871View attachment 187872
