As @t0mb0 indicated @dazzler1973 be aware the DCC50S has a solar voltage input limit at 20 odd volts DC which is why I stuck my panels in parallel.
After experimenting on my boat with series and parallel due to shading from the mast, and the fact that at anchor it never stays still ... my conclusion over a 3 week holiday was that there was no discernable difference between the two.Amazing responses @Stay Frosty and @Oceanis thanks for the help I really appreciate it. I really like the setup of both. @Oceanis it looks like you have one cable from each solar panel and then one cable feeding down through the pop top.....can I ask why you decided to go in series for your setup and not parallel for your panels? Also it looks like the same for your batteries too or am I reading the diagram wrong? if they are in series too can I ask why you choose that way and not in parallel here too please?
They have bypass circuitry, that's how I spotted a failed panel on my boat - it was in the history stored on the MPPT ... some days I was only seeing 2/3 of the normal Max Voltage (3 panels in series) and as with all things, the intermittent fault eventually became permanent.I thought when panels were wired in series and one fails you lose all output, also with a maximum potential of 350 watts available I've used 6:00mm2 cable which should be adequate for the less than 4m run.
Hi @dazzler1973 …. Both batteries are charged prior to camping via Victron blue smart charger and then via Victron 100/30 mppt solar charger using 2 175w panels if needed while on campyep horses for courses......everybody has their own specific needs and works out what is best for them......just out of curiosity @VanDamMan how do you charge them? are they plugged into a trickle charger when your done?
