No worries, cheers palSorry no........... they posted an instagram story last month.
My lights are old style incandescent bulbs and there are two reverse lights. Its an early T6 EU6 with barn doors.
Is my van abnormal?
Hi Brian,I bought my T6 in December last year at the start of summer here in Australia. Now the nights are darker and I needed reversing lights for the first time.
To my surprise I only seem to have one working reversing light on the LHS (the equivalent bulb on the RHS seems to be the rear fog light) and as a reversing light it seem to be not very bright...... In fact as a reversing light it is virtually useless; I could see more using the indicators.
Is this a common problem? or is it peculiar to my vehicle?
If it is normal can anyone suggest an improvement? I tried searching for 'Dim reversing light' but nothing relevant came up.
Brian
These are the LED reversing lights that I upgraded to and they give a much better, brighter, white light.Hi T6ARF
It's a 2017 T6 base model van called 'Runner' out here. 75 KW motor, manual 5 spd gearbox and rear tailgate. I will post a photo in the morning.
Brian
It is morning here now si I took a couple of photos of the rear lights; I haven't tried to remove the cluster yet but the LHS side seems to have a white bulb in the lowest bulb position and the RHS seems to have a red bulb? which I guess fits in with possibility that the LHS is reversing and the RHS is fog.Hi T6ARF
Brian
Barn door lights have two candles on T6 regardless of trim.
Hi AussieMick, That sounds a likely explanation but hard to understand given the harder winters and long dark nights they have in Germany. Perhaps in Germany the base model is used only as a delivery van and never leaves the street light areas.I have a 2016 t6 and my rear lights are the same as yours.
Reversing light on passenger side and fog light on drivers side.
Somewhere in the owners book it tells you of this.
Maybe in Germany this is a requirement and on startline models vw doesn't change it for overseas markets.
Loving the Toy Machine stickerAfter much trial and error I have now fitted these to my 2016 Caravelle
955 Twenty20 Impact Canbus LED 12V W16W Bulb
The retailer advised me that 'the bulbs you need are known as a 955 bulb'. I initially ordered some that were too wide in fitment.
Not very clear from the photo but they are WAY brighter (new bulb fitted on the right).
