Interested in this too, it looks like you need the caliper mounting brackets to me and possibly a different brake hose? Master cylinder should be fine
Ah good news that the brackets come with! No idea on the hose... Only one way to find out
They are 340mm discs so should be a nice upgrade!
We have a T32 150 with big brakes too, lwb if that makes a difference?
Always worth checking that your trailer brakes are working effectively, I sometimes tow a 2 tonne (gross) trailer, I've got a T30 with small brakes and it stops fine without me having to apply a great deal of pressure on the pedal, obviously the trailer brakes are making sure the van isn't trying to stop 2 tonnes pushing it forward under braking.My front disc need replacing but I would like to upgrade them. When towing my car on the trailer it really doesn't have that initial bite and they fade to much.
Oh good, worth a mention as people often forget that trailer brakes need maintenance too!Thanks All
Dave - Trailer is fine. It's a brand new Brian James trailer and when loaded with an elise it's only 1450kg. The van brakes are ok but don't inspire any confidence especially when the van is also loaded up. I also have 20" wheels with a slightly higher diameter which doesn't help the braking. I could easily live with the brakes the way they are today, but given there is a cheap OEM upgrade now could be the time to do it.
I'm using brembo pads and I don't wish to use non OEM pads like green stuff (worst pads ever).
Hopefully I'll be getting the set from Oli's customer soon.
I've found out the brake lines and master cylinder are the same for small and big brakes.
Sorry heads been up my arse this week!So do you have the big brakes or not? These posts make me unsure![]()
When towing my car on the trailer it really doesn't have that initial bite and they fade to much. I can't afford a REVO kit so I'm thinking of a upgrading to T32 brakes which is only £400, and given my small discs are £200 for Brembo ones from EuroCarParts it's not much more.
I’m bigger than the required 17” (I have 20" wheels) so clearance of the callipers is no concern (although I'm not sure about my spare wheel).
I assume T32 brakes fit any T6 ??
Do I need to upgrade the master cylinder or are they all the same size?
For the 17" chassis (big brakes) the front discs are 340mmSo what size are the bigger discs on the T32?
Some pics would be good Oli, didn't realise they'd changed themI have a set of T6.1 T32 brakes available. These are the new twin piston brakes.
@BognorMotors did these ever sell? I’m after a set myself if you have any floating about ?I have a set of T6.1 T32 brakes available. These are the new twin piston brakes.
Messagedstill available
Hi there, yes the hoses fit. Just done this job myself last month. Things to note:Quick question if you guys don't mind, I've got a bigger break kit ( not an aftermarket one, just one that you find on some of the bigger engined T32 )
I've got a T28 ( 2019 ), I've got all the calipers, disks etc. But before we go and get everything taken apart. Will the hoses already on the van work with the bigger kit ? As the kit i bought doesnt have new hoses ?
Many thanks
Do these make the braking efficacy any better, I have a '18 plate T6 T28 campervanCuston Vanz are selling them on eBay. VW TRANSPORTER T6.1 BIG BRAKES - DISCS CALIPERS AND PADS - BRAND NEW | eBay
You're correct, not all T32 had large brakes but these are.
